mini-me dizzy a6/z6 question
Old Apr 18, 2005 | 11:11 AM
jonleeone's Avatar
Default mini-me dizzy a6/z6 question
does the a6 dizzy work with a z6 dizzy housing on a z6 head.... my friend said it would work but it wont activate vtec even it i had a rpm switch or vtec controller.... my guess is he's wrong cause i read that the DX dizzy works fine and it looks like the dizzy on the DX and A6 are the same... just want to get things straight. im a noob
still learning...
still reading...
still searching...
Old Apr 18, 2005 | 12:13 PM
CRXVTEC69's Avatar
Default Re: mini-me dizzy a6/z6 question (brave)
If you are swapping the z6 head (OBD1) onto the A6 block then u will need the OBD1 dizzy as well. So to answer your ?: YES u will need the z6 dizzy as well.
Old Apr 18, 2005 | 04:33 PM
mr. carpenter's Avatar
i'm currently running the a6 dist. on a z6. the dist. doesn't activate vtec. you'll have to use the rpm activated controller if using the pm6 ecu or go obd1.
Old Apr 18, 2005 | 05:11 PM
Super Chicken's Avatar
Default Re: mini-me dizzy a6/z6 question (mr. carpenter)
Ok, sorry to thread jack, but I asked in Hybrid and have gotten nothing, so I'll ask here, Do I need a EX/SI dist or will any OBD1 Dist work? Like a CX? I'm going with a P28 ecu and doing the whole OBD0->OBD1 conversion
Old Apr 18, 2005 | 05:57 PM
92integra_gs's Avatar
Default Re: mini-me dizzy a6/z6 question (CRXVTEC69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXVTEC69 &raquo;</TD></TR><TR><TD CLASS="quote">If you are swapping the z6 head (OBD1) onto the A6 block then u will need the OBD1 dizzy as well. So to answer your ?: YES u will need the z6 dizzy as well. </TD></TR></TABLE>
not necessarily he can stay obd-0 if he want to... he just have to fabricate the dizzy mounts ... it will fit trust me i got one right now...
the only difference between the dx dizzy and si dizzy is that the si dizzy has two more wires that you will need to run mpfi.... basically crank sensors wires...
the dizzy has absolutely nothing to do with vtec... its your vtec solenoid and vtec oil pressure solenoid(this comes wid your vtec cylinder head) hook up to your ecu or ecu/vtec activator(either the vtec controller or the dial from summit) that lets you have vtec...
hopefully you guys are enlightened a bit now...
Old Apr 18, 2005 | 06:00 PM
Default Re: mini-me dizzy a6/z6 question (Super Chicken)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Super Chicken &raquo;</TD></TR><TR><TD CLASS="quote">Ok, sorry to thread jack, but I asked in Hybrid and have gotten nothing, so I'll ask here, Do I need a EX/SI dist or will any OBD1 Dist work? Like a CX? I'm going with a P28 ecu and doing the whole OBD0-&gt;OBD1 conversion</TD></TR></TABLE>
i pretty sure if you stick wid mpfi dizzy you should be fine... i forget if CX was dpfi or mpfi.. not sure... but just to be sure just get and ex/si dizzy... should ran you $40-$60 used... and $175 new...
Old Apr 19, 2005 | 03:48 PM
Default Re: mini-me dizzy a6/z6 question (92integra_gs)
Thanks for the reply. I've been watching them on E-bay and the CX/Generic ones are 10-30 and the EX/Si are 60-80 so it's a bit of a money thing
Old Apr 19, 2005 | 04:09 PM
89 pos's Avatar
i thank i have one
ef_hybrid
34
Jul 2, 2013 09:41 AM
JDMequalslife
Dec 18, 2012 04:22 PM
beyondspexj
Feb 18, 2006 07:42 PM
90civicturboed
Jul 25, 2005 08:53 PM
egizzle8
Feb 9, 2004 07:25 AM
