a ticking noise from the b16a
i have the b16a first gen in my 1990 crx, after taking it to the track i started getting a ticking noise from the head of the motor. thinking the valves needed to be adjusted, i got them adjusted. not once, but twice. ticking noise = still there.
i seem to only hear the noise when im out of vtec. after reading a couple websites one night, there was a topic talking about "Sea Foam" which is supposts to cure sticking lifters & valves, and other stuff as well. so curious i tried it. the stuff worked somewhat, but the ticking noise still haunts me every now and then. any suggestions of what it could be? and my car blows blue smoke now
, notice it was burning oil with mobil 1 synthetic as well..........
thanks
, notice it was burning oil with mobil 1 synthetic as well..........thanks
I have this ticking sound too from my first gen b16. It comes and goes and I don't hear it when I'm in vtec either, but my car doesn't smoke. It's really annoying, glad to see that someone else is having this problem.
if i had a digi cam or sound recorder. i would let you know how my engine sounds. i for one know that i need a valve adjustment and obd1 injectors.
maybe you have a minor axle/cv click that comes and goes i once had that problem. you did run at the track.
Check the health of the motor. At least do a compression test but preferably both compression and leakdown.
If it is ok I would look into the LMAs or the injectors.
Those 1st gen lost motions suck. Next time you pop the valve cover, push on the middle rocker I bet its pretty dead. Should be a bit tight to press down. I went through the same thing before.
outside of h.t i was told 2 different things
(1) i adjusted my fuel pressure to high, which resulting in cracking the tips of my injectors. -only heard it from one person
(2) the lost motion dampeners in which i heard from 2 people, and plus everyone on here that has mentioned it. so im gonna use my first lifeline and trust the audience
i was told to use type-r lost motion dampeners. go figure they would be stronger. what does everyone think?
http://cgi.ebay.com/ebaymotors...=WDVW
This is who and where I got the lmas from to fix a noisey b16a. The valvetrain
noise was eliminated. If you are ever going to upgrade your cams these are pretty much a necessity.
From: I told you to wait in the truck in Texas, United States
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 »</TD></TR><TR><TD CLASS="quote">Lost Motion Assemblies</TD></TR></TABLE>
see these links for more info:
https://honda-tech.com/zerothread?id=599337
https://honda-tech.com/zerothread?id=726701
JDM B16A
Mar 21, 2006 04:20 PM
