anyone here using slipstreams and 205/50 kumho mx's?
Old Apr 18, 2005 | 08:57 AM
itr1244's Avatar
Default anyone here using slipstreams and 205/50 kumho mx's?
i just put 205/50/15 kumho Mx's tires are very nice but i have a major problem
it rubs.... on my rear left side.. the wheel is sticking out too much.. and it rubs
what should be done to fix this?
anyone had same problem?
Old Apr 18, 2005 | 09:08 AM
p nut's Avatar
What is your suspension setup? I think Bbasso on here runs Slipstreams with MX's.
Old Apr 18, 2005 | 09:26 AM
Opie's Avatar
Basso is on oem suspension 15 x 6.5 Slips and 205/50/15 MX's
Old Apr 18, 2005 | 09:30 AM
nightrider's Avatar
Default Re: anyone here using slipstreams and 205/50 kumho mx's? (itr1244)
bbasso has had them for a while as opie mentioned, but i have never heard of any complaints. hmm...
suspension?
Old Apr 18, 2005 | 09:32 AM
Bbasso's Avatar
Sounds like you have a suspension problem...
Take off the wheel and make sure it's sitting properly.
Old Apr 18, 2005 | 01:38 PM
itr1244's Avatar
Default Re: anyone here using slipstreams and 205/50 kumho mx's? (Bbasso)
i am running omni power coilovers
i dropped the front as low as it could go and raise the back up as high as it could go
but i will have to try again see if it can go any higher
Old Apr 18, 2005 | 01:49 PM
Opie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr1244 &raquo;</TD></TR><TR><TD CLASS="quote">i dropped the front as low as it could go and raise the back up as high as it could go
You know, I'm no rocket scientist but I think that may be contributing to your problem.
Old Apr 18, 2005 | 07:05 PM
itr1244's Avatar
Default Re: anyone here using slipstreams and 205/50 kumho mx's? (opie)
i dont really know but there was something wrong or either i didnt really know how to adjust it right..
front say i have about .25" wheel gab and the back has like .50"
Old Apr 18, 2005 | 07:54 PM
jetydosa's Avatar
25 Year Member
My car was dizzumped on 205/50 MXes with 7" wide wheels and 38 offset...no rubbing. Take the wheel off, check things out, you must have some other issues.
Old Apr 19, 2005 | 11:30 AM
Bbasso's Avatar
SO... what did you find?
Old Apr 19, 2005 | 11:35 AM
itr1244's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">SO... what did you find?</TD></TR></TABLE>
thanks for looking out
yesterday i raised up my left rear suspension and i rolled my fenders more..
now it's alot better for rubbing issue but still my offset looks weird. maybe i need some more - camber on it
Old Apr 19, 2005 | 11:49 AM
Bbasso's Avatar
So your saying that only one tire/wheel is giving a problem? did you check the offset on the rim to make sure it's the same as the rest?
Seems rather odd, I have the stock suspension and does not even come close it touching anything. How low of a drop do you have? measure from the jack points.
Old Apr 19, 2005 | 12:07 PM
FrostyDC4's Avatar
"Haters Gonna Hate"
25 Year Member
How long do these tires last (I'm looking for an estimate)? Thanks!
Old Apr 19, 2005 | 12:08 PM
hadboosttroy's Avatar
Default Re: anyone here using slipstreams and 205/50 kumho mx's? (FrostyDC4)
ever heard the saying "your mileage may very"? well that's the case
sorry i can't be of more help, until you tell us the main duty these tires will see.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FrostyDC4 &raquo;</TD></TR><TR><TD CLASS="quote">How long do these tires last (I'm looking for an estimate)? Thanks!</TD></TR></TABLE>
Old Apr 19, 2005 | 12:18 PM
KayOs's Avatar
Depends on how and how much you drive-
FrostyDC4's Avatar
"Haters Gonna Hate"
25 Year Member
Default Re: anyone here using slipstreams and 205/50 kumho mx's? (hadboosttroy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hadboosttroy &raquo;</TD></TR><TR><TD CLASS="quote">ever heard the saying "your mileage may very"? well that's the case
sorry i can't be of more help, until you tell us the main duty these tires will see.</TD></TR></TABLE>
Street + auto-x. I'm looking for something comparable to the S-03 (in treadwear and in grip). If the MX's dont compare to the S-03 I'll just have to fork out the $$$ for another set of S-03 ($150+ per tire is kinda steep ). Sorry to go OT.
Old Apr 19, 2005 | 12:21 PM
Bbasso's Avatar
I got about 20k out of them, and no easy driving
few track days and burnouts
Old Apr 19, 2005 | 12:48 PM
p nut's Avatar
S03's will outperform the MX's for sure, but it's up to you to decide whether it's worth it or not.
Old Apr 19, 2005 | 01:02 PM
Bbasso's Avatar
Default Re: anyone here using slipstreams and 205/50 kumho mx's? (P Nut)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P Nut &raquo;</TD></TR><TR><TD CLASS="quote">S03's will outperform the MX's for sure, but it's up to you to decide whether it's worth it or not.</TD></TR></TABLE>
I just read a bunch of reviews on the S03's and each one of them said they wear out with 15k miles if not sooner if your driving hard. And on that note... $134 a tire that last 10-15 miles is not a good deal.
Even though the MXs are a little less in the performance dept, they have lasted 20k miles and only cost me $400 installed. Seems like a better all a round deal.
My thoughts are based on street use. not track.
Track is a different subject.
Old Apr 19, 2005 | 01:03 PM
Chris N's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr1244 &raquo;</TD></TR><TR><TD CLASS="quote">i am running omni power coilovers
Um... yea. YTF would you do that?
Old Apr 19, 2005 | 01:13 PM
p nut's Avatar
Track is a different subject.</TD></TR></TABLE>
Yeah, they won't last as long as the MX's. I was just basically telling the guy if it's worth it for him to spend a little more $$ and get faster times, then do it, and if not, MX's seem to be a good choice.
Also, I hope the S03's last more than 10-15 miles
Old Apr 19, 2005 | 01:21 PM
itr1244's Avatar
Default Re: anyone here using slipstreams and 205/50 kumho mx's? (Chris N)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris N &raquo;</TD></TR><TR><TD CLASS="quote">
Um... yea. YTF would you do that?</TD></TR></TABLE>
i dun know but i wanted my car to sit a little lower on the front than the back
to achieve that i had to do that. but there's not much differance between front and back wheels gap.
front has about less than a finger gap and the back has about a finger gap
i will post some pics later
Old Apr 19, 2005 | 01:28 PM
itr1244's Avatar
Old Apr 19, 2005 | 01:31 PM
p nut's Avatar
Blur your plates, yo
Old Apr 19, 2005 | 03:18 PM
Jowee's Avatar
Looks like the camber is off. Try one of these:
http://cgi.ebay.com/ebaymotors...33581
http://cgi.ebay.com/ebaymotors...33583
Are you sure all the wheels have the same offset?
