center console/arm rest switch holes?
okay, there are 4 pop out switch templates right under the e-brake. What are they for? I wanted to put some acesory switches in there, but I wanted a switch that would EXACTLY fit the holes. Anybody know anything that would work?
Modified by bigt61 at 7:19 AM 4/18/2005
i have a switch in my center console.. i use it for interior neons.. any type of switch will work fine just make sure that you wire it carefully and away from the gearbox... youll need to take apart the whole center console to do it so if you need help with that just reply back and ill give you a step by step on that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSRracing95 »</TD></TR><TR><TD CLASS="quote">i have a switch in my center console.. i use it for interior neons.. any type of switch will work fine just make sure that you wire it carefully and away from the gearbox... youll need to take apart the whole center console to do it so if you need help with that just reply back and ill give you a step by step on that.</TD></TR></TABLE>
Yes, I know how to take apart the center console. I have not found a switch that replaces the factory pop-out template in the console. I want a switch that will fit the hole without any cutting or any other problems. I wanted to know if someone knew where I could get a direct-fit switch? Do you have pictures of your switch set-up LSRacing95?
JDubya
Nov 13, 2003 07:01 PM
