brake light problem: when stepping on the brake, interior light comes on also?
Old Apr 18, 2005 | 05:23 AM
91integraLSVTEC's Avatar
Default brake light problem: when stepping on the brake, interior light comes on also?
i need help fixing this problem asap on my 95 honda civic ex. when i have my headlights on, my brake lights doesnt work at all but when i have my headlights off my brake lights turn on but dim, and so does my interior lights every time i step on the brake!! this just happended yesterday. what should i check for? thanks in advance
Old Apr 18, 2005 | 06:49 AM
Cuong-nutz's Avatar
Default Re: brake light problem: when stepping on the brake, interior light comes on also? (91integraLSVTEC)
most likely you have a wire grounding out somewhere. Did you mess with the trunk or under the dash? Could be something to do with the combination switch, but I can't make out why your interior light would come on unless you have a faulty door switch thingmabob. Check the your tail lights and see if you have any loose or exposed wires touching each other or metal.
Old Apr 18, 2005 | 07:38 AM
Ninety5Ex's Avatar
I'm almost 100% sure it's one of your brake bulbs if you haven't messed with any wires lately. Check all the brake bulbs. Since they are dual filament, it's possible that the connectors melted and are "soldered" together
Old Apr 20, 2005 | 06:16 AM
Default Re: (Ninety5Ex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ninety5Ex &raquo;</TD></TR><TR><TD CLASS="quote">I'm almost 100% sure it's one of your brake bulbs if you haven't messed with any wires lately. Check all the brake bulbs. Since they are dual filament, it's possible that the connectors melted and are "soldered" together</TD></TR></TABLE>
thanks for all the replys! you were right, one of my brake bulbs blew and it was damaged ( i cud turn the glass part on the socket). changed that bulb and the excorsim stopped!
kornkid21792
Jan 21, 2010 03:27 AM
804tuned
Lighting
Jan 17, 2010 05:44 AM
Egpower88
Nov 5, 2009 01:12 PM
Captain JDM
Oct 23, 2006 11:35 AM
sadiusomega
Jul 27, 2005 08:43 PM
