Distributor problems : ICM or Distributor housing?
Old Jan 30, 2002 | 12:13 PM
IntegD's Avatar
New User
Default Distributor problems : ICM or Distributor housing?
Ok..Ive had some distributor problems before, but they occured while driving. Ive changed everything on it once(a while ago), and now it didnt start at school. So, I checked for spark, there was none, so I swapped coils...that wasnt it. Then, I used my friends b16a dist.(obd1) and it worked. SO, that leaves only the housing or ICM(ignitor)...my question is, is there any way to determine whichone it is without using a voltmeter, as I dont know how to use one. thanks in advance..
P.S. I didnt test my friends ICM because his screws are on the inside of the cap..mine are on the outside of the housing(that hold in the ICM)
Old Jan 30, 2002 | 04:49 PM
kenji's Avatar
25 Year Member
Default Re: Distributor problems : ICM or Distributor housing? (IntegD)
Try taking the ignitor out of your buddy's distributor and see if that is the problem.
But, to be honest with you...I would just get another distributor. It will be about the same price and a lot less hassle.
-kenji
Old Apr 2, 2004 | 10:16 AM
TwoPointZero's Avatar
Banned
Default Re: Distributor problems : ICM or Distributor housing? (kenji)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegD &raquo;</TD></TR><TR><TD CLASS="quote">Ok..Ive had some distributor problems before, but they occured while driving. Ive changed everything on it once(a while ago), and now it didnt start at school. So, I checked for spark, there was none, so I swapped coils...that wasnt it. Then, I used my friends b16a dist.(obd1) and it worked. SO, that leaves only the housing or ICM(ignitor)...my question is, is there any way to determine whichone it is without using a voltmeter, as I dont know how to use one. thanks in advance..
Back from the dead. I need to know if the ignitor is the problem
warfield21
Apr 15, 2017 12:26 PM
movingIIshadow
May 17, 2006 09:28 PM
metalgears
Aug 28, 2004 11:22 PM
