What spark plugs are you guys running ??
I am looking for some new plugs for my R and I am considering Bosch Platinum 2 (the ones with 2 tips), Denso Iridiums, TorqueMasters, NGK... Anyway, I'd like to hear from you guys ... My car has a little extra compression by means of a Spoon 2-ply head gasket and I plan to install an MSD ignition system (SCI, Blaster 2, MSD wires). Thanks for the info !!
Dispite what others have said. I have had great luck with my Bosch Platinum +4's I know people here don't like them but My car is running better than ever. No problems....Although I may try some iridiums for the hell of it.
I threw my platinum fours in the dumpster, I wouldn't even give those to someone, poor throttle response, slow starts, and I blame them in part for my 147sae hp/104sae torque dyno run yesterday.....nkg's or you'll be mad at yourself
It looks like its a close battle between NGK and Iridiums (DENSO).... If I stick with the NGKs, considering I have added compression and an upgraded ignition system (MSD 6A with Blaster coil), should I go cooler on the plugs ?? Thanks !!
Your running HKS Spark Plugs? Didn't know they existed...but thats kewl
Suprdave
BTW: I run Nippon Denso, the Bosch were causing some spotting in Cylinder #4.
Getting NGk for Spring Tune-Up.
[Modified by Suprdave, 8:56 PM 2/2/2002]
Suprdave
NGK
