Will Integra Calipers fit 92-95 Civic Si ?
Old Apr 18, 2005 | 04:22 AM
JoJoNz's Avatar
Default Will 94-01 Integra Calipers fit 92-95 Civic Si ?
Will front and rear 94-01 Integra Calipers fit 92-95 Civic Si ?
Old Apr 18, 2005 | 04:23 AM
pdiggitydogg's Avatar
abs equipped si? The one w/ 10" rotors?
If so, then yes.
Old Apr 18, 2005 | 04:25 AM
JoJoNz's Avatar
Default Re: (pdiggitydogg)
non abs Si. I guess it won't fit then
Modified by JoJoNz at 8:57 AM 4/18/2005
Old Apr 18, 2005 | 07:45 AM
egsleepercivic's Avatar
I am pretty sure if you have a 94-95 it will have the 10' rotors on the front, my 94 ex without abs does....
Old Apr 18, 2005 | 08:16 AM
Its mostly a matter of the rotor size than abs
Old Apr 18, 2005 | 09:04 AM
94eg!'s Avatar
#1 Super Guy
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egsleepercivic &raquo;</TD></TR><TR><TD CLASS="quote">I am pretty sure if you have a 94-95 it will have the 10' rotors on the front, my 94 ex without abs does....</TD></TR></TABLE>
All 92-00 EX's have 10.2" front brakes.
All 92-00 civics with ABS have 10.2" front brakes
The rest of the civics have 9.4" fronts.
If you have 9.4" fronts, you will need to get the proper steering knuckles to use the larger brakes (rotors, calipers, and master cylinder)...
Old Apr 18, 2005 | 09:51 AM
^ will a 92 si with 4 wheel disk non abs have the 10" rotors.
Old Apr 18, 2005 | 10:13 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: (egsleepercivic)
NO
9.4" front
9.4" rear
13/16" master cylinder
40/30 proportioning valve
Old Apr 18, 2005 | 11:10 AM
so if I upgrade to the 10" brakes on the si will I need a different prop valve
Old Apr 18, 2005 | 11:20 AM
POE's Avatar
POE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egsleepercivic &raquo;</TD></TR><TR><TD CLASS="quote">so if I upgrade to the 10" brakes on the si will I need a different prop valve</TD></TR></TABLE>
nah, that mostly deals with the rear disc breaks, u just need the MC
Old Apr 18, 2005 | 11:34 AM
^Thanks^
Old Apr 18, 2005 | 12:07 PM
No, because you already have rear disc
For the fronts you need ex/em1/integra knuckles
Old Apr 18, 2005 | 01:00 PM
I'm planning on swappint them out with my ex, that would make my ex brakes the same as a dx correct?
Old Apr 18, 2005 | 01:18 PM
94eg!'s Avatar
#1 Super Guy
Loved
In theory...
If you upgrade your fronts with the EX calipers/rotors, the ideal MC to get would be the 7/8" 94 Del Sol VTEC (only NON ABS dohc vtec model). This will be the identicle setup to the EG6 SIR2 in japan...
Old Apr 18, 2005 | 01:39 PM
thinking about stepping it up a notch and goin with 15/16 91 ex 4 door non abs 4 disk MC...what you think? also 7/8 is what is on the ex also...
Old Apr 18, 2005 | 01:42 PM
fastwanabe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egsleepercivic &raquo;</TD></TR><TR><TD CLASS="quote">thinking about stepping it up a notch and goin with 15/16 91 ex 4 door non abs 4 disk MC...what you think? also 7/8 is what is on the ex also...</TD></TR></TABLE>I have this exact setup and it works great(15/16). I just swapped out the MC and it made a big difference.
Old Apr 18, 2005 | 01:54 PM
No, ex are larger than dx.
Old Apr 18, 2005 | 02:16 PM
94eg!'s Avatar
#1 Super Guy
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">No, ex are larger than dx.</TD></TR></TABLE>
He is saying that he is going to swap the front brakes on his EX & Si. This means his EX will now have DX style brakes all around.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egsleepercivic &raquo;</TD></TR><TR><TD CLASS="quote">...also 7/8 is what is on the ex also...</TD></TR></TABLE>
If that's the case, I would just swap master cylinders too. There is no reason to spend $70-$150 when you don't have too...
A couple questions for you then:
What year EX?
What model EX (2dr/4dr)?
Does it have ABS?
Old Apr 18, 2005 | 02:26 PM
94 ex 10" fronts non abs 2dr
I can MC from autozone for about $60 or less
Old Apr 18, 2005 | 02:37 PM
94eg!'s Avatar
#1 Super Guy
Loved
It's your money...
SLPRcivic
Jul 14, 2009 12:17 PM
alexb18c1
Jul 10, 2008 04:04 AM
TiGASNANGULO
Dec 9, 2007 11:16 AM
GReatEDDY
16
Sep 19, 2006 08:43 PM
slow94coupe
Jan 13, 2005 08:28 AM
