any solutions to rust?
Old Apr 18, 2005 | 02:36 AM
mdarnell's Avatar
Default any solutions to rust?
i bought an si shell...its got some pretty hefty rust spots...mainly on rear quarter panel...prev owner bondo'd over it... can i be fiberglassed? or fixed at all?
Old Apr 18, 2005 | 02:45 AM
EFB16ACRX
Guest
Posts: n/a
Default Re: any solutions to rust? (mdarnell)
get rid of it, dont cover it up, rust will not stop.
Old Apr 18, 2005 | 02:59 AM
jc836's Avatar
Take ALL of the bondo off and look carefully at the sheetmetal. You need to decide if replacing the entire quarter is worth ~$1400 per side in a shop. True you can cut the replacement panel and only put on what you think will do the job-cost will be lower. Full replacement, including repairing the inner structure-it is a streesed member of the car-is best left to pro's. You need to find the source of the problem and attack it completely. There are some very good products out there (POR-15 for example) that will help reduce rusting over the long term. Keeping the body clean underneath is very important too.
Old Apr 18, 2005 | 03:02 AM
Jeff's Avatar
Banned
I have the same problem. It's going to be a cut and paste scenerio. I am bringing it to a body shop. They basically cut out the rust then weld on new metal work it in then make it flow with the car. Then the day it's done I am rust proofing it. Then after a few weeks of the rust proof chillin on the car I clean off the excess rust proofing then I am painting the car. It will be about 1000$ in body work.
Old Apr 18, 2005 | 03:15 AM
mdarnell's Avatar
Default Re: (Jeff)
thanks for the advice....i have a while before i can do any work on the car...my job has me traveling all over the east coast..wish i could take it with me
Old Apr 18, 2005 | 04:47 AM
Idiotboy's Avatar
Im currently in the process of fixing the rust on my CRX, the whole rear bumper frame peice was rusted to hell, and the in side of the wheel wells near the rear were rusted through to the inside of the car. Three days with a hammer and angle grinder (broke the grinder on the third day) got rid of the majority of the major rust, only a few spots left on the actual body. This week its on to repairing all the wholes and repainting.
Moral of the story, if the rust isnt too bad you can probably fix it your self and save some money. If you need welding or cutting done, thats a different story, but always see if you can do it yourself first, you save money and get satisfaction knowing you did the job your way and to your standards
Bendito
Paint and Body
Dec 21, 2015 07:42 PM
-[95cxhatch]-
14
Feb 14, 2006 08:31 AM
NXLude
Oct 11, 2005 05:21 PM
rexosaurus
Aug 15, 2005 10:14 AM
95GSRTT
Welding / Fabrication
Oct 2, 2004 09:47 AM
