B18B into EK..need quick HELP!!!
Old Apr 17, 2005 | 10:51 PM
grlracer97's Avatar
Default B18B into EK..need quick HELP!!!
Ok, so we got a B18B OBD1 in my 97 civic but a couple things don't add up. The accelerator cable (not sure the real name, sorry) that hooks to the throttle body was cut before shipment and the D- series appears to be too short. Any suggestions as to which cable to use or how to make this work?
Also, my brother said that everything from the OBD2 plugs hooked up fine to the OBD1 engine so my question is will I still need to do the IAVC splice with the ECU and plug? I'm sure that codes will fly at start up because the engine appears to have an OBD2 throttle body, OBD1 short and long block, and distributor, and a B16 tranny. Does anyone know specifically what problems we might run into at start up or what else needs to be changed? Oh and the oil pressure sensor hooked right up to the plug so I'm guessing we won't need to relocate it? Someone on here told me I may need to.
Just to fill in I have bought the brackets, axles and an SI shift linkage. I appreciate the help guys. We're struggling here.
I reposted this here b/c I wasn't getting anything from Civic forum. Thanks
Old Apr 18, 2005 | 09:51 PM
grlracer97's Avatar
Default Re: B18B into EK..need quick HELP!!! (grlracer97)
ttt
Old Apr 19, 2005 | 09:32 PM
fred 150's Avatar
are you using the factory wire harness
Old Apr 19, 2005 | 09:47 PM
grlracer97's Avatar
Default Re: B18B into EK..need quick HELP!!! (fred 150)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fred 150 &raquo;</TD></TR><TR><TD CLASS="quote">are you using the factory wire harness</TD></TR></TABLE>
Yeah, I'm using the civic harness. I think my brother is using only one plug from the LS harness because he torn one up when switching the engines. Also using the DX ECU (OBD2). We are awaiting an integra throttle cable and the intake manifold gasket to finish setup, so we haven't started it up yet to see what codes will be thrown.
Also, getting tool from Honda dealer (dad works there) to get that damn shift linkage pin out so we change that over as well.
Still don't know if anything needs to be done to the IAVC or if I will need to relocate oil pressure sensor since those plugs right up???
Old Apr 19, 2005 | 09:56 PM
fred 150's Avatar
Its going to shoot a code because its obd1. did you hook up the crank sensor, intake temp, and both o2 sensors?
Old Apr 19, 2005 | 10:05 PM
grlracer97's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fred 150 &raquo;</TD></TR><TR><TD CLASS="quote">Its going to shoot a code because its obd1. did you hook up the crank sensor, intake temp, and both o2 sensors? </TD></TR></TABLE>
As far as I know he has everything hooked up except the secondary O2 sensor which were gonna weld into the downpipe. Oh there are a couple plugs on the intake that bolt to the back of the throttle body that he hasn't hooked up yet because we are waiting for the gasket and all so we haven't really plug it all up. The throttle body appears to be OBD2 though because it has the black injector plugs but I don't know how much of a difference that will make at start-up.
AdrenalineAngel
Oct 27, 2012 08:25 PM
LS-turboner
Jan 24, 2010 06:55 AM
grlracer97
Apr 17, 2005 08:41 PM
g2homboi
Apr 27, 2004 09:44 PM
