Very loud timing belt
Old Apr 17, 2005 | 09:10 PM
fasthatchb18c1's Avatar
Default Very loud timing belt
Well I just put my B18c in my hatchback, just got finished converting everthing over from auto to manual that i needed too. I started my car up about 10 mins ago and the timming belt was makeing a very loud screaming noise, then i noticed that the intake side of the belt is very loose and the exauhst side it very tight. Just want to know if this has anything to do with this swap because the motor was fine about 4 months ago in my other hatch.
Old Apr 18, 2005 | 06:00 AM
H22A_civic's Avatar
if your timing belt is making noise, it's becuase it's on to tight.
Old Apr 18, 2005 | 02:01 PM
Default Re: (H22A_civic)
yeah i fixed it last night
Old Apr 19, 2005 | 06:36 AM
j87w's Avatar
Default Re: Very loud timing belt (fasthatchb18c1)
So if its loose on one side and tight on the other, it would be because the tension on the belt is not correct.
Old Apr 19, 2005 | 09:54 AM
ben1818's Avatar
Default Re: Very loud timing belt (j87w)
if its like mine it should have a self tensonor that you have to take out to change the belt and you have to have a special tool or rig something up to put back in are you on on all of the teath and how old is the belt
Old Apr 19, 2005 | 11:30 AM
well it was the tensioner so I put the cams TDC and loosen tension turn crank 3 teeth and it fixed it
EJ1B18c
Feb 4, 2009 06:44 AM
kevtec_00
Jan 19, 2005 03:30 AM
petrv
Feb 25, 2004 10:32 PM
obd2gsr
Dec 21, 2002 08:53 PM
nerdish
Jul 17, 2001 11:22 PM
