b18b swap into EK...top rad hose was whistleing..
Old Apr 17, 2005 | 08:32 PM
Capt. Jimbo McSubipants's Avatar
Default b18b swap into EK...top rad hose was whistleing..
just did my swap on my EK..with a b18b
took it for a drive...and it runs good...lol actually..side note...just took it out...brand new motor mounts...i didn't put on the AC mount tho....bad idea....pretty new clutch too with azenis....took it down the road...hit second hard...motor just blew the shiz outta that driver side mount lol....but...i made the mount better when i got home and were back to normal...
but anyways...took it for a drive after that and after like 20 mins of beatin on her...i hear this whistleing...and i'm like wtf?? pull into a drive and its just smokin....but...temp gauge is at normal...so i pop the hood...and the rad just has fluid spoo'in everywhere...is the rad fucked or is somethin plugged..i can't see anything being plugged b/c the motor was fine at operating temps...
FYI i was usin the D15b7 intercooler from an EG..a.k.a its a *******...but it shoulda atleast worked...
i'm swappin it for a GSR rad but i just wanted some info
Old Apr 17, 2005 | 08:40 PM
handa's Avatar
Default Re: b18b swap into EK...top rad hose was whistleing.. (b16delteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16delteg &raquo;</TD></TR><TR><TD CLASS="quote">
FYI i was usin the D15b7 intercooler from an EG..a.k.a its a *******...but it shoulda atleast worked...</TD></TR></TABLE>
so i see it as a turbo'd b18b?
Old Apr 17, 2005 | 08:48 PM
Prod's Avatar
prob just leaking, if im not mitaken the bseries hose isn't exactly the right diameter for that rad so thats a common leak spot...just get a clamp and tighten that hose connection real good.
Old Apr 17, 2005 | 09:56 PM
clutcher's Avatar
Also, consider replacing the radiator... get a bigger one that can move and cool more fluid at a time.
Old Apr 18, 2005 | 07:24 AM
Prod's Avatar
Default Re: (clutcher)
and why should he get a bigger rad ?
seeing as how the stock half size will work completely fine
Old Apr 18, 2005 | 07:31 AM
EVIL Hx Coupe's Avatar
Default Re: (Prod)
The B series hose is bigger than the little tube on the Dseries radiator, if you use the B series hose with the stock clamp it wont be able to seal pefectly and when you build pressure it's gonna leak out of there.
You can either get yourself one of those clamps with the screw on it and tighten it really good using the bseries hose, or just heat up the end of the dseries hose to make it fit the bseries motor and the other end will fit perfect on the rad.
Old Apr 18, 2005 | 01:55 PM
Default Re: (EVIL Hx Coupe)
umm just got a GSR rad...works great..thank tho..the other rad was just ****..
DangercartSi
May 22, 2009 08:51 AM
D_TY3
Aug 16, 2007 07:35 PM
wpgcivic
Nov 21, 2004 08:26 AM
mugenek007
Nov 2, 2004 04:50 PM
Ransom
Sep 10, 2003 11:36 AM
