strange thunking noise, help asap
Old Apr 17, 2005 | 06:54 PM
b18-c-rx's Avatar
Default strange thunking noise, help asap
When I go over large enough bumps, accelerate quickly, or slam on the brakes, there is a distinct thump, heard outside and inside (and you can even feel it in the floor) coming from somewhere (i believe) around the firewall or suspension.
This just started happening after I installed my Full-Race traction bar. It sounds like something's hitting the firewall. My engine is, as far as i can tell, not touching anything, and my mounts are torqued.
Does anyone have any ideas?
thanks
Old Apr 17, 2005 | 07:01 PM
DocSean's Avatar
Did you get the car aligned afterwards?
Old Apr 17, 2005 | 07:02 PM
FalkenSiR's Avatar
Default Re: strange thunking noise, help asap (b18-c-rx)
I'm not a genious on traction bars, but if they go on the crossmember bolts, then you may want to get a big *** impact and tighten the **** out of it.
I used to have a clunk from my front end, and i tightened my crossmember bolts and it went away. Yes, our cars are at least 12 years old, and things tend to get loose. In your case, you might not have tightened them enough. Hey, at least give it a try.
Old Apr 17, 2005 | 07:58 PM
b18-c-rx's Avatar
Default Re: strange thunking noise, help asap (fast88std)
well, here's the deal:
it's aligned, yes
and
I tightened the hell out of them at first, then took them back down to spec. didnt seem to make a difference. I tightened the two huge bolts that go straight up to 40 ft-lbs, but the 6 side bolts i did not tighten to any spec. could that actually be the problem?
Old Apr 17, 2005 | 08:05 PM
DocSean's Avatar
can't hurt to go torque them down.
Old Apr 17, 2005 | 08:46 PM
b18-c-rx's Avatar
Default Re: (spankjelly)
I don't know what the torque value is. it's the 3-bolts on the towing hooks.. anyone knwo the tq val?
Old Apr 17, 2005 | 08:57 PM
b18-c-rx's Avatar
Default Re: (b18-c-rx)
somehow, I just dont think this is the problem.. any other ideas?
Old Apr 17, 2005 | 09:09 PM
DocSean's Avatar
Do you have access to a lift or a couple floor jacks?
Old Apr 17, 2005 | 09:43 PM
b18-c-rx's Avatar
no, i got my gsr engine in the rex without any of those, no prob
lol
Yeah I have jacks.. I went around and tried tightening everything i could find... it was all good.
I even had ryan (droppedcrxsi), as well as his friend peter, look at it
Old Apr 18, 2005 | 07:06 AM
b18-c-rx's Avatar
bump for suggestions
honda671
Aug 17, 2013 11:37 AM
FacelessDrummer
Feb 9, 2005 02:12 PM
hYpE-R-29
Jul 19, 2002 03:27 PM
J Ritt
Aug 1, 2001 11:44 AM
J Ritt
Aug 1, 2001 10:41 AM
