Need Help Fast!!!
Old Aug 1, 2001 | 09:04 AM
J Ritt's Avatar
Default Need Help Fast!!!
Hi guys,
I'm leaving for the track at noon tomorrow, and my car is making a clunking noise under certain circumstances: I've been able to replicate the noise under hard braking, sharp turns to the right, and even on a hard uphill launch.
It sounds like a clunk, not metallic, but like something is shifting in place. It sounds like it is coming from the drivers side front corner of the car.
I initially thought it was the driver's side driveshaft because both boots on that side had holes and were spitting grease...i thought water got in and caused a problem. However, Acura replaced the driveshaft under warranty last week and the car is still making the noise. I also checked all of the suspension bolts on both sides in front last week, and they were all at spec.
Any ideas on what it could be?!?! Could it be the shock itself? I'm at a loss...can't figure out where the sound is coming from. I'm freaking out a bit because I am taking the car to the track tomorrow, and don't want something nasty to happen if something lets go. Please give me some suggestions to try and locate the source of the noise!
Old Aug 1, 2001 | 09:06 AM
Willard's Avatar
Default Re: Need Help Fast!!! (J Ritt)
brake pads moving around in the caliper.?
my car makes sounds similar to what you describe...
Willis
Old Aug 1, 2001 | 09:07 AM
Chris's Avatar
Do you have aftermarket suspension?
Is everything out from under the seats?
Old Aug 1, 2001 | 09:08 AM
Chris's Avatar
Default Re: Need Help Fast!!! (Chris)
Try it with the brakes lightly applied...same noise???
Hooch'n's Avatar
If it is a "big clunk", then it might be the Tranny. I had a tranny go on my Neon and it made a big clunk and then it would drop into gear. You might want to have it checked out.
Old Aug 1, 2001 | 09:09 AM
Hooch'n's Avatar
Default Re: Need Help Fast!!! (8400-RPM)
Then again, your tranny isn't in the front right of the car!
Old Aug 1, 2001 | 09:18 AM
tjtruong's Avatar
New User
Default Re: Need Help Fast!!! (George Knighton)
I interested also in what the problem is. Keep us informed!!!
tjtruong
Old Aug 1, 2001 | 09:30 AM
J Ritt's Avatar
Default Re: Need Help Fast!!! (tjtruong)
Thanks guys, keep em coming.
The car has been on the track 3 times...some autox. Nothing really too heavy duty other than that. No drag racing. I drive it like a granny on the street most of the time.
I'm going to be changing the brake pads, so I'll check that out tonight.
Suspension components are now back to stock. I had King A arms on the front, but swapped them out to make sure it wasn't the ball joints making the noise. It's still making the noise with the stock arms.
Maybe it is the wheel bearings? I just went out and looked at the suspension again...everything is solid as hell.
Keep coming with the suggestions guys. thanks a million.
Old Aug 1, 2001 | 09:36 AM
Chris's Avatar
Lift up the front, insert key and turn 1 click(but do not start) Go and grab wheels at 9 and 3 o'clock, shake like you are trying to turn the wheels back and forth. If there is that clunk, then its tie rod bushings or other suspension, if it shakes while holding at 12 and 6 o'clock its wheel bearings
Old Aug 1, 2001 | 09:43 AM
Snapspinnr's Avatar
New User
Try what Chris said.
My left front wheel bearing had to be replaced. It made clunking noises that sound similar to what you are describing.
Shawn
[Modified by Snapspinnr, 10:43 AM 8/1/2001]
Old Aug 1, 2001 | 09:49 AM
Chris's Avatar
You're such a good moderator.
aww shucks! I actually learned that when I had my lowrider!!!
The shake up and down I figured out watching Taz Harveys guys(family!)....
[edit] Or was that sarcastic??!! [/edit]
Old Aug 1, 2001 | 09:53 AM
yoshi234's Avatar
I shoot brides
could also be one of the motor mounts
yoshi - who's civic clunked b/c of a bad front tranny mount
Old Aug 1, 2001 | 10:15 AM
CMH's Avatar
CMH
How long ago did it start? Just after the dealer did the axles?
Aside from the brakes (my first guess, mine does that), check the wheel bearings the way Chris mentioned, but I'm on my original wheel bearings with 130K of hard miles.
Does the car still handle well?
Old Aug 1, 2001 | 10:41 AM
J Ritt's Avatar
Default Re: Need Help Fast!!! (CMH)
Damn Geeser...you even brought it out of retirement and took it to the boards! You make me feel special... I'll play with it when I get home from work...which i'm sure will be around 11...doh!!! This was happening before the dealer touched it. Thanks as always.
NightStalker
Apr 2, 2007 05:48 AM
StinkyTofu
Honda S2000
Aug 7, 2004 11:39 PM
Holding monSteR
May 4, 2004 02:00 PM
J Ritt
Aug 1, 2001 11:44 AM
