power lag on old accord
Old Apr 17, 2005 | 05:17 PM
drewcandraw's Avatar
Default power lag on old accord
well my friend has an early 90s accord and he told me that it kinda jerks and loses power under 20 mph.....when i drove it and pressed on the accelerator it started driving normally but then after a while it lagged and felt like the engien couldnt get power and it jerked then went forward. its an automatic and i was wondering if its the transmission???any help would be good thanks
Old Apr 17, 2005 | 05:21 PM
twobit's Avatar
Default Re: power lag on old accord (drewcandraw)
Happened to my brothers old 91 accord...sadly it's the tranny :-\ unless you wanna spend 1200 bucks then have fun
Old Apr 17, 2005 | 05:43 PM
bshshondaman06's Avatar
f series tranny's are cheap.... if u install it urself. but yea it sounds like its going out
Old Apr 18, 2005 | 06:53 AM
SearchBeforeUPost!'s Avatar
Default Re: (bshshondaman06)
Sounds like a transmission issue. Check the level and condition of the fluid. It could be a little low. If it is dark and has a burnt smell, take it somewhere and have it flushed out and refilled.
Old Apr 20, 2005 | 07:27 PM
Default Re: (SearchBeforeUPost!)
would replacing the transmission fluid help the car last a little longer???cause my friend really doesnt have the money
Old Apr 20, 2005 | 11:05 PM
Mr_EmO's Avatar
Default Re: (drewcandraw)
flushing the tranny cost some where around $70?
Old Apr 21, 2005 | 03:29 AM
H2290's Avatar
Default Re: (Mr_EmO)
Flushing the tranny could be bad for it. You could blow out the chunks of crap that are sitll holding the thing together. Check the fluid and add if necessary. Tell him to start saving for an F22B.
Old Apr 21, 2005 | 05:15 AM
-RedneckDave-'s Avatar
Working
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drewcandraw &raquo;</TD></TR><TR><TD CLASS="quote">would replacing the transmission fluid help the car last a little longer???cause my friend really doesnt have the money</TD></TR></TABLE>
Flushing the trans is not bad however H2290 is correct, it could loosen particles in the case and in turn causing a total failure of the trans. The best route to take is to replace the trans and the torque converter.
Old Apr 21, 2005 | 09:43 AM
Schmitey's Avatar
Default Re: (H2290)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H2290 &raquo;</TD></TR><TR><TD CLASS="quote">Flushing the tranny could be bad for it. You could blow out the chunks of crap that are sitll holding the thing together. Check the fluid and add if necessary. Tell him to start saving for an F22B. </TD></TR></TABLE>
Every good mechanic I've talked to has told me the same. If it hasn't been flushed regularly they you're probably doing more harm than good with that many miles on it.
Just throwing this out there...it couldn't be clogged EGR could it since it sounds like it does it after it warms up?
*Yet another reason I got a stick!
Old Apr 21, 2005 | 04:40 PM
Default Re: (Schmitey)
my friend is asking how much the fseries tranny would cost him???
NYPito
Apr 7, 2013 01:31 PM
dieboy
May 22, 2011 05:33 AM
stevo accord
May 2, 2009 10:40 AM
mugenaccord503
May 18, 2006 06:29 AM
eg686
Dec 7, 2005 07:03 PM
