B&M FPR with LS/VTEC question
Old Apr 17, 2005 | 02:08 PM
kasso's Avatar
Default B&M FPR with LS/VTEC question
I just finished my LS/VTEC install and it was idling really high (like 2000 rpm). so after adjusting the throttle body screw and retarding the timing a bit, i got the idle to 1500 rpm. then after accidentily pinching the FPR's vacuum line, the idle went down. so, i capped off the vacuum line and now Im running the FPR with no vacuum source. car is running good and not consuming too much fuel. just wondering if i really need a vacuum source on the FPR?? TIA.
Old Apr 17, 2005 | 02:14 PM
kasso's Avatar
Default Re: B&M FPR with LS/VTEC question (kasso)
also, do i need a b16 power steering bracket to hook up power steering? or will the ls bracket work fine?
Old Apr 17, 2005 | 03:37 PM
Redline130's Avatar
The FPR isn't going to work correctly if there isn't a vaccum source.
Old Apr 17, 2005 | 04:17 PM
kasso's Avatar
Default Re: B&M FPR with LS/VTEC question (Redline130)
how else would i adjust the idle? the MAP sensor? and what about the LS P/S bracket?
Old Apr 17, 2005 | 04:19 PM
Redline130's Avatar
Have you checked for any other vaccum leaks? Have you turned the t/b screw as much as it will go?
Old Apr 17, 2005 | 04:42 PM
D-tuned's Avatar
sounds like you have a vaccum leak. the FPR needs a vaccum to work correctly. about the power steering, you need the uppper P/S brackets for the head that you have. Example, if you have a b16 head, you need to get a b16 upper bracket.
Old Apr 17, 2005 | 05:17 PM
kasso's Avatar
Default Re: B&M FPR with LS/VTEC question (2000civicsi)
quick question... with the vacuum hooked up to the FPR, would fuel pressure go up as more air goes in?
Old Apr 17, 2005 | 05:55 PM
D-tuned's Avatar
if your boosted it would. its a 1:1 fpr. that means for every pound of boost it sees, its going to raise the fuel pressure 1 psi.
carlos8
Sep 7, 2016 07:44 AM
dark_reverie
Aug 15, 2014 12:39 PM
Looneytunerz
Nov 1, 2012 06:34 AM
sk8phaze
Aug 16, 2002 10:45 AM
