96-97 GSR front seats into a 00 Civic SI?? SEARCHED!!
I've searched and all I can find is an s2000 seat into a civic. If anyone has put a GSR seats into a 00 Civic SI, I wanna know how you did it. I've looked at swapping rails but it's just way too different to swap. Thanks.
Modified by blkcivicpn0i at 6:27 PM 4/18/2005
Searched under gsr seat, integra seat, dc seat, acura seat, nothing about how to fit a 96 Integra gsr seat into a 96-00 Honda Civic coupe! If you find how to do it then I'll shut up and read it. Thanks for trying tho.
Can't. Rails bolt up differently. The rails on the Gsr seats are bolted by two bolts on the bottom of the seats. While the 00 civic seats are bolted on the sides.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blkcivicpn0i »</TD></TR><TR><TD CLASS="quote">Can't. Rails bolt up differently. The rails on the Gsr seats are bolted by two bolts on the bottom of the seats. While the 00 civic seats are bolted on the sides. </TD></TR></TABLE>
you can if you have both seats, just switch the inner rails....I had 96 GSr seats in my 96 civic CX, now my friend has them in his. we did the rail swap 2 times.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blkcivicpn0i »</TD></TR><TR><TD CLASS="quote">I've searched and all I can find is an s2000 seat into a civic. If anyone has put a GSR seats into a 00 Civic SI, I wanna know how you did it. I've looked at swapping rails but it's just way too different to swap. Thanks.</TD></TR></TABLE>
All DC2 seats can be swapped into EK's by swapping the inner rail (the rail with the seatbelt buckle). Then they bolt down on all 4 bolts. Don't complain, just do it and you'll see they work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twinbros »</TD></TR><TR><TD CLASS="quote">http://www.geocities.com/Motor....html
What year GSR seat?</TD></TR></TABLE>
That was a nice find, I dont think I have ever seen that before.
What year integra do they look like they came from? I tried swapping the inner rails but they are bolted on the bottom of the seats instead of on the side like the 00 civic seats.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef9turbohatch »</TD></TR><TR><TD CLASS="quote">swap the damn seat rails....they will fit....
Seriously, it isn't difficult at all. I swapped my Civic rails onto del Sol seats without a problem. I haven't heard of any problems with Integra seats into Civics, either. Can you put a socket on a wrench? Can you move your arms to loosen and tighten bolts? Then you're fine. I'd say the most demanding aspect of installing seats is just lifting them in/out and making sure not to scratch any door panels with the seat rails. Also, make sure that the slider wire is tight; if not, re-bend it with muscles and pliers (what I had to do). Works fine that way.
</TD></TR></TABLE>Seriously, it isn't difficult at all. I swapped my Civic rails onto del Sol seats without a problem. I haven't heard of any problems with Integra seats into Civics, either. Can you put a socket on a wrench? Can you move your arms to loosen and tighten bolts? Then you're fine. I'd say the most demanding aspect of installing seats is just lifting them in/out and making sure not to scratch any door panels with the seat rails. Also, make sure that the slider wire is tight; if not, re-bend it with muscles and pliers (what I had to do). Works fine that way.
Have you swapped 93 integra seat rails onto a 00 civic seat? If not stfu, you aint helping by being a smartass and telling me you've swapped a "DELSOL RAIL ONTO A CIVIC SEAT" duh mothafucka I've done it and if you can read, it aint del sol seats, s2000 seats nor 94-01 integra seats. It's a 93 Acura Integra Seat<U></U>. I've taken them apart and I know for sure they're not mounted the same way. Soooo if you can't answer my question, then your reply is useless to me.
For everyone else that has "READ" and replied with a knowledgeable response, thanks for the help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blkcivicpn0i »</TD></TR><TR><TD CLASS="quote">Have you swapped 93 integra seat rails onto a 00 civic seat? If not stfu, you aint helping by being a smartass and telling me you've swapped a "DELSOL RAIL ONTO A CIVIC SEAT" duh mothafucka I've done it and if you can read, it aint del sol seats, s2000 seats nor 94-01 integra seats. It's a 93 Acura Integra Seat<U></U>. I've taken them apart and I know for sure they're not mounted the same way. Soooo if you can't answer my question, then your reply is useless to me.
Thats really not what you want to say if you are asking others for help, just relax a little.
</TD></TR></TABLE>Thats really not what you want to say if you are asking others for help, just relax a little.
</br>
