Sputtering b16 Please help Searched
Old Apr 17, 2005 | 01:53 PM
StreetEG's Avatar
Default Sputtering b16 Please help Searched
So i searched and found that my situation is unique.. after like 5 pages of sputtering posts. This is going to sound stupid but this is what my car is doing. If a normal run through 3rd gear sounds like this on a non sputtering motor
bwahhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh
mine sounds like
bwahh bidabahhhh bidabwahhhh bwah bwah bwah
I just changed my sparks, fuel filter, and i had 2 injector that were leaking thrugh the o-rings a little that i replaced. I also swapped dizzys with another car and it dihelped but not fully.
It starts up and idles fine, and doesnt do it in first but under any throttle in 2nd-5th. It is the most annoyin thing in the world and is frustrating and embarrasing to drive.
Mods list
b16a
short ram intake
worldsport exhaust
mugen chipped p28
PLease help, should i get a new distributor? is this timing? or would timing be more severe. Ive spent hours searching
Eric
Old Apr 17, 2005 | 03:00 PM
StreetEG's Avatar
Default Re: Sputtering b16 Please help Searched (StreetEG)
Old Apr 17, 2005 | 03:24 PM
PureBlood's Avatar
Same issue in my car when i did my swap, it would idle fine, but it was screwed under load.... It ended up being the Wire-harness ground. Check your grounds. then reset your ecu and go again.
Old Apr 17, 2005 | 05:23 PM
StreetEG's Avatar
Default Re: (PureBlood)
the ground!? hmm that would save a lot of wasted money
Old Apr 19, 2005 | 01:04 PM
StreetEG's Avatar
Default Re: (StreetEG)
Turns out it was the ground wire!... cleaned em up and it still sputters but a very little bit...im going today to pick up some ring terminals to redo all the grounds with new 4 and 8 guage wire.
Hopefully itll turn out
Old Apr 19, 2005 | 03:26 PM
EJ8VTEC's Avatar
Mr. Indecisive
let us know how it goes
Old Apr 24, 2005 | 12:52 PM
StreetEG's Avatar
Default Re: (CoupeVtec2k)
spoon header + new 4 guage ground wires all around = no sputter/breaking up. Its amazing to have a stong sounding car again
alx_jdm_99
Jan 16, 2010 09:36 AM
xsialex
Nov 1, 2009 12:25 PM
92eg_b16
Dec 12, 2007 06:44 PM
EF-21
Mar 24, 2004 05:48 AM
