Throttle position sensor for ZEX?
Old Apr 17, 2005 | 09:14 AM
d16rice's Avatar
Default Throttle position sensor for ZEX?
I’m sure I can find the throttle position sensor, but which wire should I tap into for the ZEX activation at W.O.T.
Old Apr 17, 2005 | 09:59 AM
d16rice's Avatar
Default Re: Throttle position sensor for ZEX? (d16rice)
Old Apr 17, 2005 | 10:25 AM
d16rice's Avatar
There are three wires going to the civic throttle position sensor:
Breen/black
Yellow/blue
Red/black
One of the wires form ZEX box is supposed to be connected to the WOT switch:
White
Which wire (green, yellow, or red) is the white (ZEX) wired supposed to be connected to?
Old Apr 17, 2005 | 10:33 AM
d16rice's Avatar
Is it the RED/black wire?
Honda civic (1996-1998) and Accura Integra (1994-1998) Haynes “Automotive Repair Manual”
“…connect the probes of the voltmeter to the red/black wire and ground.”
“Gradually open the throttle valve and observe the TPS voltage. With the throttle valve fully closed, the voltage should read approximately 0.5 volts. Slowly move the throttle valve and see if the voltage changes as the sensor travels from idle to full throttle. The voltage should increase smoothly to approximately 4.5 volts.”
Can any one confirm this.
Old Apr 17, 2005 | 10:44 AM
jlacoy82's Avatar
71.192.16.183
Yes thats correct (the voltages).
Old Apr 17, 2005 | 10:45 AM
d16rice's Avatar
Default Re: Throttle position sensor for ZEX? (jlacoy82)
I know the voltage is correct because I got it out of the manual, but is this the wire I hook it up to?
RED/BLACK --> WHITE
Old Apr 17, 2005 | 10:51 AM
jlacoy82's Avatar
71.192.16.183
Find the wire that has 4.5 volts on it when at WOT, and connect it to that.
92prelude23
Jan 26, 2009 05:43 PM
team2n1hatch
Jun 26, 2004 11:19 AM
Bobby-SiR
Jun 20, 2003 12:03 AM
Evil EG
Dec 12, 2002 10:18 PM
1sick4door
Dec 9, 2001 10:05 PM
