valves tapping cause oil burn?
Old Apr 17, 2005 | 07:48 AM
user 98292739's Avatar
Default valves tapping cause oil burn?
so yea...i havent had time to do a valve adjustment yet..but its tapping like crazy...would that cause me to burn oil?
Old Apr 17, 2005 | 07:56 AM
gnar kill's Avatar
Default Re: valves tapping cause oil burn? (LoCoReX)
ummm....I dunno about the burning oil.....but you need to adjust your valves because it is really not that hard to do and you will hate yourself if you burn a valve....
Old Apr 17, 2005 | 08:09 AM
MENACE's Avatar
Default Re: valves tapping cause oil burn? (gnar kill)
If the Tapping is loud Enuff i would be concerned that you may have a bent valve. And a bent Valve will cause oil Burn.
Also a Burnt Valve will to....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gnar kill &raquo;</TD></TR><TR><TD CLASS="quote">ummm....I dunno about the burning oil.....but you need to adjust your valves because it is really not that hard to do and you will hate yourself if you burn a valve....</TD></TR></TABLE>
Follow this dudes advice pull the vavle cover off and adjust them. If it still ticks, then something is more than likely bent.
Old Apr 17, 2005 | 09:38 AM
there is a write up on c racing for a b is there one for a d?
Old Apr 17, 2005 | 08:22 PM
gnar kill's Avatar
Default Re: (LoCoReX)
hey man check this out...later on he adjusts valves
http://www.geocities.com/senpa....html
rondogg779
Oct 28, 2019 11:19 PM
Jhicks
Feb 3, 2012 05:58 AM
Petah
Honda Civic (2001 - 2005)
Apr 26, 2007 03:07 AM
NomacGSR
Aug 1, 2003 05:19 AM
