Code 43...
Old Apr 16, 2005 | 11:51 PM
athoughts's Avatar
Default Code 43...
Alright still driving untuned, been like a month..
I got a CEL and i checked it and it came up..
43: Fuel supply system
ideas?
p&p head
3 angle valve job
AEBS intake manifold
AEM cia
AEM fuel rail
4-1 header
HKS cat back
test pipe
AEM cam gears/pully
Gude stage 2 cams
B&M FPR
62mm TB
- yes dual post -
Old Apr 17, 2005 | 09:54 AM
athoughts's Avatar
Default Re: Code 43... (athoughts)
Old Apr 17, 2005 | 10:02 AM
airplan727's Avatar
Start checking the fuel suppy system. Pump, lines, filter, rail, injectors. Pump could be bad, lines or filter or injectors or rail could be clogged. I don't know. Start at the front and work your way back after making sure your pump is kicking on.
Old Apr 17, 2005 | 10:08 AM
Jmunk's Avatar
Could be a bad oxygen sensor, fuel pump, fuel pressure regualtor, clogged fuel filter.
Old Apr 17, 2005 | 10:10 AM
athoughts's Avatar
Default Re: (Jmunk)
could be.. does it meen anything that the CEL came on on my way home, and once i turned the car off, it hasnt come back on yet..
Old Apr 17, 2005 | 02:26 PM
athoughts's Avatar
Default Re: (athoughts)
Old Apr 17, 2005 | 04:11 PM
airplan727's Avatar
Sometimes a faulty code get thrown. You know what the code was, so reset the ECU and see if it ever comes back. If it doesn't then there isn't a problem, if it comes back the second time then you can really start worrying. Until it comes back just be prepared for something to be wrong. ie: have some funds for a fuel pump, etc. If it doesn't come back then hey, you just saved all the money and you can spend it on something else!
Old Apr 21, 2005 | 06:44 PM
{StatuS ChecK}'s Avatar
Default Re: (airplan727)
na, if you are highly modified. or have alot of fuel mods, this can be normal. I have this code all the time. For Me, it is cause I am running rich. And my o2 sensor is probly cover with carbon and/or unburnt fuel. Much like a fouled out sparkplug.
Old Apr 21, 2005 | 06:52 PM
EJ8VTEC's Avatar
Mr. Indecisive
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by athoughts &raquo;</TD></TR><TR><TD CLASS="quote">Alright still driving untuned </TD></TR></TABLE>
thats y... did it come on at a certain rpm?? Ithink like {StatuS ChecK} said ur prolly runnin rich! Get ur **** tuned man, in certain situations driving untuned even a few miles can cause alot of damage, pistons start melting n **** like that
Old Apr 21, 2005 | 08:57 PM
athoughts's Avatar
Default Re: Code 43... (CoupeVtec2k)
yeah its been like 1000 miles now probably
Tuning at AEBS failed, so i have to wait and contact church
Old Apr 22, 2005 | 08:09 AM
EJ8VTEC's Avatar
Mr. Indecisive
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by athoughts &raquo;</TD></TR><TR><TD CLASS="quote">yeah its been like 1000 miles now probably
Tuning at AEBS failed, so i have to wait and contact church </TD></TR></TABLE>
what happened??
Old Apr 22, 2005 | 08:25 AM
athoughts's Avatar
Tuning on hondata s200
I was schedualed to put it on the dyno at 11am wednesday, when i get there, i wait around for a few
Everything is goign smoothly, about 10 mintues to plug everything in and get ready to go..
He starts writin me a new map, once we have the new map ready to be burned to the chip, we run into problems..
My car started throwing a CEL everytime we started it, after trying to fix it for about an hour he finally says that his laptop/programs are nto working, and were done.
Bill said that the computer is not letting him fully burn the program onto the chip, for some wack reason
He then told me he didnt want to waste any more of my time and i drove home still untuned.
Never made it to one pull
Old Apr 23, 2005 | 09:29 PM
EJ8VTEC's Avatar
Mr. Indecisive
sux man
Old Apr 24, 2005 | 06:30 AM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by athoughts &raquo;</TD></TR><TR><TD CLASS="quote">could be.. does it meen anything that the CEL came on on my way home, and once i turned the car off, it hasnt come back on yet.. </TD></TR></TABLE>
When was the fuel filter last changed? Did the CEL originate when you were accelerating hard? I ask this because debris can pack in a filter at high flow rates and block the flow. When the car is shut off and flow ceases, the debris can unpack and the symptoms temporarily go away.
CorrodeONE
Feb 2, 2009 10:02 PM
cincispeedemon
Nov 22, 2004 05:51 PM
im a monster hehe
Feb 20, 2004 09:45 PM
blackcracker
Oct 25, 2002 06:13 PM
