Hey guys look at my times slip, first time runing with 342WHP.
Old Apr 16, 2005 | 06:58 PM
leadfoot78's Avatar
Default Hey guys look at my times slip, first time runing with 342WHP.
R/T - 0831
60' - 2.268
330 - 5.931
1/8 - 8.786
1/8 MPH 88.82
1/4 - 13.212
MPH - 114.22
That was the second run in the car, the first was a 13.3 at 112MPH. The setup is a stock bore GSR block with an LS crank, FR kit, 60-1 turbo, full 3in ex, traction bars, 225/50/15 drag radials, makes 342WHP and 230WTQ. What times is that car capable of based on the trap speeds, I know it can do better cuz I am a shitty driver that has been proven plenty of times. I'm also reeving to 8k only, I hit the rev limit at least once on the second run.
Old Apr 16, 2005 | 07:01 PM
EF-EF's Avatar
damn your a terrible driver...just keep practicing...
Old Apr 16, 2005 | 07:03 PM
TurboJesse
Guest
Posts: n/a
Default Re: (EF-EF)
i'd expect better traps in a hatch...I went 121mph with a stock b16 making 310whp in a del sol ( it was gutted though)
Either way 114 is good for low 12's on slicks ( maybe high 11's if you can drive)
Old Apr 16, 2005 | 08:45 PM
Ls1 FD3s's Avatar
Default Re: (Mpir3)
pending your weight, you should be good for high 11s... Theres a few members with 300whp, some LESS than 300whp cracking high 11s on 1.6-1.7 60foots. Around 2000-2200lbs with driver.
I ran a 13.7 on a stock internalled GSR with bolt ons ALL MOTOR. keep practicing! and get those 60's into the sub 1.90 range!
Old Apr 16, 2005 | 09:24 PM
turboEGhatch's Avatar
Default Re: (Ls1 FD3s)
Unless your car weighs like 3000 pounds with you in it, those are some hella low traps. Assuming an average 2500 pound car, and not peddaling it like you were, that should go 120-123 on a full pass, and low 11's should be in reach.
Old Apr 17, 2005 | 10:42 AM
vaporboy12's Avatar
Default Re: (turboEGhatch)
i trapped 122.05 with 45 more hp in an integra. 12.19
you got room to improve!
Old Apr 17, 2005 | 10:51 AM
Cor ey's Avatar
I can has title
Default Re: (vaporboy12)
You have room to improve like everyone else was saying. I ran a 12.4@111 with my evo before I had cams and such. Granted I have awd, but my 60' times were around a 1.8. Get some slicks and you get be down in the low 12's...good luck getting those high 11's it will be tough.
HamiltonRex
Jun 11, 2006 07:10 AM
B18PoweredCivic
Apr 24, 2003 09:43 AM
AZHottie
Jan 14, 2003 05:41 AM
CovertFI
May 21, 2002 03:16 PM
pagong
May 9, 2002 11:36 PM
