Car started...now it won't...give me some ideas...
Old Apr 16, 2005 | 05:41 PM
1.8EG-T's Avatar
Default Car started...now it won't...give me some ideas...
I finished my gsr swap today. The car fired right up, mind you it was a 3000 rpms, due to a tight cable...and the vtec solenoid not having a gasket, so it leaked...I stopped the car, corrected the solenoid and the throttle...now the car will not start. The check engine light comes on awful slow most of the time and the brake light comes on fast...I cleaned all of the ground, the tranny gr, the valve cover gr and the thermostat ground. Battery is at 12 volts before starting...what is the culpret...please hellp a guy out, I need the car monday.
Old Apr 16, 2005 | 07:05 PM
DFW's Avatar
DFW
Default Re: Car started...now it won't...give me some ideas... (1.8EG-T)
What was the CEL code?
Old Apr 16, 2005 | 07:10 PM
1.8EG-T's Avatar
Default Re: Car started...now it won't...give me some ideas... (DFW)
No code, no cel...the light comes on when you put the key in, however now it barely came on...the fuel pump did not prime...however after sitting for a few(30) minutes it did prime, and after attempting a start then the pump did not again. I think maybe it is the battery, I am changing it in the morning, but am unsure as of yet.
Old Apr 16, 2005 | 09:09 PM
1.8EG-T's Avatar
Old Apr 17, 2005 | 07:59 AM
1.8EG-T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.8EG-T &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
Old Apr 17, 2005 | 09:49 AM
1.8EG-T's Avatar
Update, the solenoid is not getting power, but I get 12 volts at the clutch interlock switch...
Old Apr 17, 2005 | 09:57 AM
Jmunk's Avatar
Sounds like a plug is loose. Is the ground on the starter loose ? Double check the thermostat ground and the tranny ground. Sounds like the ground wire wiggled off the starter a bit or a plug needs pushed in more/connected.
Old Apr 17, 2005 | 12:01 PM
1.8EG-T's Avatar
Default Re: (Jmunk)
Actually now, 12 volts to the starter, by both plugs, but it doesn't start...had the starter tested at autozone and it is good...any ideas before I have to pay the man...
Old Apr 17, 2005 | 03:05 PM
1.8EG-T's Avatar
Default Re: (1.8EG-T)
Nm...got it started...freaking ground...ha ha ha...
yochris
Oct 1, 2015 01:52 PM
wifesaynogo
Sep 18, 2006 05:42 AM
Cielmerlion
Feb 21, 2005 01:21 PM
all_motoref9
May 27, 2004 12:57 PM
