Need urgent help
Old Apr 16, 2005 | 05:37 PM
T25So's Avatar
Default Need urgent help
I have a 96 sol with a y8 in it, and for the life of me, I cant find the torque mounts. I looked at a diagram and it showed them but i still cant find them.
Any help? Im trying to install inserts
Thanks
Old Apr 16, 2005 | 06:15 PM
Lord Helmet's Avatar
Default Re: Need urgent help (T25So)
https://honda-tech.com/zerothread?id=550976 look down the page(user: B18C5-EH) on that link, it will show you all the moiunts you need. BTW they are normally called tranny mounts or engine mounts not torque mounts.
Old Apr 16, 2005 | 09:23 PM
hatchi's Avatar
torque mounts are under the frame on the fronts if you look up in there your a/c bracket and front tranny bracket goes through it
Old Apr 16, 2005 | 09:31 PM
civictildeath's Avatar
Default Re: Need urgent help (sleeperciv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeperciv &raquo;</TD></TR><TR><TD CLASS="quote">BTW they are normally called tranny mounts or engine mounts not torque mounts. </TD></TR></TABLE>
there are certain ones that are called torque mounts because they are only needed when toque is applied to engine
B_Swapped93
Oct 28, 2013 06:22 AM
Tire Monkey
May 2, 2004 05:23 PM
turbo*s2k
Feb 29, 2004 07:46 PM
Screamer
Oct 23, 2003 11:43 PM
