do you thing my ball joint is bad?
Old Apr 16, 2005 | 04:43 PM
ablack934doorcivic's Avatar
Default do you thing my ball joint is bad?
i hear a annoying squeeking noise when i turn my wheel not all the time though. but i did notice it also makes this noise when i stop and take off again and when i get out of the car after i drive i can hear what sounds like my car squeeking from the car raising up slightly. what in your oppinon would cause this maybe a bad inner tie rod????
Old Apr 16, 2005 | 05:06 PM
komat's Avatar
Default Re: do you thing my ball joint is bad? (ablack934doorcivic)
its probably the cv joint
Old Apr 16, 2005 | 05:57 PM
Default Re: do you thing my ball joint is bad? (komat)
thanks alot.
Old Apr 16, 2005 | 06:04 PM
Lord Helmet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat &raquo;</TD></TR><TR><TD CLASS="quote">its probably the cv joint</TD></TR></TABLE>
cv joints don't squeak
for original poster look for deteriorating suspension bushings.
Old Apr 16, 2005 | 08:28 PM
RARE_EG2's Avatar
i had a problem similar to that..it was my ball joint..i replaced it and the squeaking went away..they just happen to wear out with age..
Old Apr 16, 2005 | 09:41 PM
egtwincam's Avatar
check all your bushings. got a camber kit? polyurethane bushings. they always need to be lubed. bad struts will also cause this problem.
ld1985
Oct 23, 2009 11:14 AM
ScubaSteveSi
Sep 9, 2007 08:59 AM
littleblue
13
Jul 27, 2006 09:15 PM
rudeman85
Nov 4, 2004 01:19 PM
B-B-K
Oct 4, 2004 12:00 PM
