need help. confirm this. putting motor back together, when start timing belt slips
Old Apr 16, 2005 | 04:10 PM
gaydm.accord's Avatar
Default need help. confirm this. putting motor back together, when start timing belt slips
ok so im putting my motor back together and i go and start the car after setting everything to tdc. once i try to start i can hear the car turn over but then i hear a slight noise of pressure letting loose. i go out and check and see that my cranks tdc is no longer in line with my cam gears tdc. im sure im doing everything right.
i did a search and came up with replacing my tensioner. can someone confirm this. and does this happen often?
when putting belt back. here's how i did it.
set crank pulley to tdc mark. set cams/gears to tdc by setting them to 0 and also looking into the cam caps check. now pull intake side of belt up and over the cam gears then slide other side on. should have 1 in deflection in between gears. turn crank pulley over 3 teethes then tighten tensioner.
Old Apr 16, 2005 | 05:07 PM
ok i went back and put the belt on exhaust side first, it turns and back fires nothing.. im pretty sure i have my dizzy on correctly. so far it didnt skip teeths but then again i only cranked it over once.
firing order is
3 4
2 1
4 3 2 1
Old Apr 16, 2005 | 07:03 PM
fixed problem. took dizzy out turned shaft connecting point 180 degrees and put it back on.
1SlowSi
Aug 26, 2005 04:04 AM
redlseg
Apr 20, 2005 07:07 PM
EKB18BPR3
Dec 9, 2003 07:08 PM
kefka
Apr 8, 2002 08:40 PM
