ITR radiator into a GSR...possible?
Old Apr 16, 2005 | 03:41 PM
sinister357's Avatar
Default ITR radiator into a GSR...possible?
does anyone know if the radiator and fan assembly from an ITR would be a direct fit into a GSR. any diffrence in between the two? the reason i ask is i need a replacement and found a good price on one but it's from an ITR. thanks in advance.
Old Apr 16, 2005 | 03:50 PM
Comp97GSR's Avatar
Default Re: ITR radiator into a GSR...possible? (sinister357)
It will fit.
Old Apr 16, 2005 | 04:08 PM
Default Re: ITR radiator into a GSR...possible? (Comp97GSR)
i'm still wondering because i was brousing through password jdm and noticed that they offer a radiator support only for the type r. just got me thinking... anyone else thats actually have experience in this?
Old Apr 16, 2005 | 04:25 PM
1999all_motoR_teg's Avatar
You sure it's not the JDM ITR front end rad support they are offering?? They will fit into either vehicle GSR into ITR and ITR into GSR to my knowledge.
Old Apr 16, 2005 | 04:28 PM
baonest's Avatar
Default Re: ITR radiator into a GSR...possible? (1999all_motoR_teg)
all those damn rads are the same. or at least they should be.
Old Apr 16, 2005 | 09:13 PM
t0ekn3e's Avatar
the radiator support is for the front end i belive
Old Apr 16, 2005 | 11:03 PM
rG`'s Avatar
rG`
Yes, it will fit.
Old Apr 17, 2005 | 06:20 AM
Stunna BEN's Avatar
Don't call it a comeback
Default Re: ITR radiator into a GSR...possible? (r`Geno)
why dont you use a civic one?
Old Apr 17, 2005 | 07:04 AM
igyloo's Avatar
be sure you get both fans, the A/C fan is the same, but the primary is different
Old Apr 17, 2005 | 10:30 AM
cheeks97R's Avatar
they r both the same, or u could go civic fluidyne and that will make vtec reeealy kick nice!
Old Apr 17, 2005 | 11:42 AM
itr1244's Avatar
it is possible FOR SURE
they are probably same size and should drop right in
you can fit civic rad in to teg no problem so.. teg rad to another teg rad shouldnt be problem AT ALL
Old Apr 17, 2005 | 11:55 AM
Default Re: ITR radiator into a GSR...possible? (itr1244)
thanks for all the inputs. it's appreciated. now from what you guys say, it should fit? i think thats good enough for me. i'll go ahead and order the radiator and hope for the best. any other comments are always welcome.
Old Apr 17, 2005 | 09:27 PM
stumpyf4's Avatar
http://www.acuraparts247.com list the part numbers for 1998 Integras as (manual transmissions):
LS: 19010-P73-023
GS-R: 19010-P72-A03
ITR: 19010-P73-A03
When I bought my aftermarket rad, it was for all integras. It has 2 mounts for the fans and a tranny cooler for auto integras. Safe to say get the fans with your GSR rad.
Old Apr 19, 2005 | 11:37 AM
Default Re: ITR radiator into a GSR...possible? (stumpyf4)
what's up with the diffrent part numbers! can anyone confirm on the fitment of this radiator?? i need to know - actually it's too late now. the typr r radiator is on it's way here already. i'll let you guys know when it does get here sometime this week if anyone's interested. later
Old Apr 19, 2005 | 11:41 AM
B-money's Avatar
they should work, I put a GSR rad. into my ITR.
Old Apr 19, 2005 | 11:42 AM
m R g S r's Avatar
get a civic half length pwr one....it will free up alot of space, which you may need in the future([cough] turbo [cough]).....
Old Apr 19, 2005 | 12:01 PM
Default Re: ITR radiator into a GSR...possible? (m R g S r)
oh...forgot to mention...it's a JDM type R radiator. so i'm guessing it'll either fit or be totally off or maybe just needs a bit of tweaking here and there... thats the fun of this sport/hobby, i guess. not knowing what to expect until you do it yourself.
Old Apr 19, 2005 | 12:04 PM
AoiGSR's Avatar
25 Year Member
i know a USDM ITR OEM rad did not fit in a GSR with the GSR existing fans. you'd have to replace the GSR fans to ITR OEM to fit.
-Aoibot, who tried it.
Old Apr 19, 2005 | 12:12 PM
Default Re: ITR radiator into a GSR...possible? (AoiGSR)
luckly it comes with fans. hopefully it'll all just plug in.
Old Apr 19, 2005 | 12:15 PM
KayOs's Avatar
If anything you may have to relocate the radiator support brackets. Should fit though.
sinister357
Apr 17, 2005 12:46 PM
B-money
Jul 29, 2004 06:15 PM
rated_r
Jul 19, 2004 03:32 AM
Blazeone
Mar 11, 2004 03:06 PM
Rob Dizzle
Oct 9, 2002 12:40 PM
