Mini-me Project
Old Apr 16, 2005 | 02:57 PM
BigAnold's Avatar
Default Mini-me Project
I am in the process of doing a mini-me swap on my 89 CRX. So far I started with a shell for $80, and a 91 CRX Si motor for $80 also which I am rebuilding now. I have bought an Apex'i vtec contoller and a Z6 head to do the swap so far. After I get some more money I will be converting it to OBD1 and using the D16Z6 ecu. I would like to know though if anyone has tried going with forced induction on this swap. I have heard it nets a somewhat high compression around 12:1 I believe and I don't really want to lower it and lose power at the same time. This car is not a daily driver as I have another vehicle so downtime is no problem but any help would be appreciated.
Old Apr 16, 2005 | 03:06 PM
kulangot's Avatar
Default Re: Mini-me Project (BigAnold)
the compression is not going to be that high on a stock a6 block....not for sure what it will be, but you can run a turbo on it...
Old Apr 16, 2005 | 03:14 PM
BigAnold's Avatar
Once I get the head on I'm going to measure the comprssion to make sure. Hopefully If all goes well I should have it running and painted in about 2-3 weeks. I have some pics but I don't think I can post yet.
Old Apr 16, 2005 | 05:16 PM
crx_of_fury's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigAnold &raquo;</TD></TR><TR><TD CLASS="quote">I am in the process of doing a mini-me swap on my 89 CRX. So far I started with a shell for $80, and a 91 CRX Si motor for $80 also which I am rebuilding now. I have bought an Apex'i vtec contoller and a Z6 head to do the swap so far. After I get some more money I will be converting it to OBD1 and using the D16Z6 ecu. I would like to know though if anyone has tried going with forced induction on this swap. I have heard it nets a somewhat high compression around 12:1 I believe and I don't really want to lower it and lose power at the same time. This car is not a daily driver as I have another vehicle so downtime is no problem but any help would be appreciated.</TD></TR></TABLE>
here is an idea, TRY DOING A SEARCH
Old Apr 16, 2005 | 09:08 PM
BigAnold's Avatar
Heres an idea, already did, thanks for the update. Now I actually wopuld have liked an answer instead of someone trying to gain posts by repeating what they were told when they first joined.
Old Apr 16, 2005 | 09:33 PM
CSprogR34's Avatar
Default Re: (BigAnold)
I agree with you, I f*ckin hate when people just post to say "USE THE SEARCH FEATURE", wtf, this is a forum, and you talk to others, if you needed to search something, im sure you already know how to use google or some other sh*t.
try to be helpful, dont post to say RESEARCH, cause it doesnt help.
/end of rant.
good luck with your swap buddy.
-Loz
Old Apr 17, 2005 | 04:43 AM
92integra_gs's Avatar
your cr is only gonna be around 10:2:1 to 10:5:1
IMO if you use a thin metal headgasket from the Y8 it should help up the CR... but if you really want to get 12s on it try to swap out the pistons w/ d16a1 (zc pistons) w/ LS rods...
btw good luck wid this project...
and yes people have used turbo on the mini-me setup... but use low CR around 9:5:1
Old Apr 17, 2005 | 07:58 AM
D21X's Avatar
Default Re: (92integra_gs)
d16z6 head with a d16a6 block will get 9.95:1 compression. and all d-series share the same headgasket now (3-layer metal), no difference between Y8 and Z6 or any of them.
Old Apr 17, 2005 | 09:09 AM
bagpipe goatee's Avatar
well, at the dealer maybe. some auto stores still sell the old composite type.
Old Apr 17, 2005 | 10:12 AM
BigAnold's Avatar
Thanks for the info guys, I do appreciate it. I just signed up for a cardomain site and I'll keep posting on progress.
drockcrx
Nov 12, 2009 10:58 AM
nomoreavril
10
Apr 26, 2008 07:28 AM
AJxr
Oct 16, 2005 09:11 PM
AJxr
Sep 27, 2005 11:12 AM
rtenzo02
Jun 6, 2004 06:00 PM
