oil pressure sender question
i just got a sunpro oil psi gauge. and i want to make sure it has everything i need before i do anything. it came with high temp. nylon tubing, 1/8" and 1/4" NPT thread fitings...so this is everything i need correct?
No you will need a 1/8 NPT to 1/8 BSPT adapter fitting for the block.
The block is 1/8 BSPT NOT 1/8 NPT
Are you just planning on leaving the stock pressure switch un hooked?
I wouldn’t but that’s me...
torqueless
Apr 19, 2007 03:29 AM
Petah
19
May 6, 2002 05:41 AM
