ITR and Skunk2 PRIMERY lobe specs?
Old Jan 30, 2002 | 06:56 AM
HX_Guy's Avatar
Default ITR and Skunk2 PRIMERY lobe specs?
Does anyone know the specs of the non-vtec lobes on stock ITR cams and the Skunk2 Stage 2?
Old Jan 30, 2002 | 07:49 AM
HX_Guy's Avatar
Default Re: ITR and Skunk2 PRIMERY lobe specs? (HX_Guy)
Anyone? I need to know if there is a differance in duration (to lower compression)
Old Jan 30, 2002 | 07:59 AM
D's Avatar
D
what the hell are you talking about?
Old Jan 30, 2002 | 08:00 AM
HX_Guy's Avatar
Default Re: ITR and Skunk2 PRIMERY lobe specs? (D)
Duration helps lower dynamic compression
Old Jan 30, 2002 | 08:07 AM
D's Avatar
D
i don't think many people give a rats *** about the primary lobes... i have a 01 intake ITR cam sitting here, that i'm getting around to mapping the lobes iwth a dial indicator to finally settle the 01 - pre 99 cam difference. if this is something vitally important to you, i can waste some additional time on primary lobes in addition to vtec lobes.
D
Old Jan 30, 2002 | 08:09 AM
HX_Guy's Avatar
The reason I would like to know is, as I said, to see if it would affect the compression any. I get detonation at lower RPMs (not in VTEC).
Old Jan 30, 2002 | 08:24 AM
TypeR0149's Avatar
D
where the hell did you get that cam from?
Old Jan 30, 2002 | 08:33 AM
D's Avatar
D
Default Re: ITR and Skunk2 PRIMERY lobe specs? (Vegeta)
Old Jan 30, 2002 | 08:46 AM
sgT's Avatar
sgT
Duration alone doesnt affect compression, OVERLAP does.
Only cams like toda B&C are going to have significant overlap on the
pri/sec lobes. Hence the low vacuum idle.
All the cams YOU want are weak down low hence stock idle(no overlap)
Old Jan 30, 2002 | 08:47 AM
HX_Guy's Avatar
Default Re: ITR and Skunk2 PRIMERY lobe specs? (sgT)
Well that sucks
Miracle11
Jun 2, 2010 09:07 PM
crxb16a90
Jan 6, 2010 01:54 PM
G3gsr
Feb 2, 2003 02:40 AM
Malice
Nov 19, 2001 11:24 AM
