h22 guys what kind of compression number are you seeing?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head »</TD></TR><TR><TD CLASS="quote">Just need some general idea about what kind of normal number should i see on a h22 off a 97 lude.
thanks in advance</TD></TR></TABLE>
Well, that depends on your setup, are you blown? or NA? Lower compression headgasket? it all differs. Let us know! I'm actually taking mine today from my turbo'd 4th gen to see if I have a blown headgasket. I'll post up numbers later!
thanks in advance</TD></TR></TABLE>Well, that depends on your setup, are you blown? or NA? Lower compression headgasket? it all differs. Let us know! I'm actually taking mine today from my turbo'd 4th gen to see if I have a blown headgasket. I'll post up numbers later!
Stock H22 head, OEM head gasket, H22A1 block with OS Type S pistons, 215 to 220 all the way across.
It also depends on where you live, IIRC, and the condition of your motor.
My H23 VTEC at 11.1:1 CR hit ~250 psi on all four, while my buddy w/ his older H22 hit ~240......carbon can bring your numbers up.
