Door actuator stutters when unlock? WEIRD!?
As stated, not sure why it stutters everytime I unlock the car. Anyone ever has this problem? Wonder is it a simple fix, due to something being misaligned? or should I just replace the whole actuator lock?
Everything still works as normal, just that it UNLOCKS and STUTTERS at least 5+ times, then stop. Still locks and unlocks though.
Its getting really annoying, sometimes, kind of embarassing. LOL! Let me know if theres any solution. Thanks!
96-GSR
2Dr (if that matters)
96-GSR
sounds like something is stuck/needs to be cleaned.
electrical problems are a pain...usually it's easiest to just replace the part.
Yea, electrical isnt really my likes.
Was hoping if someone actually had this weird same problem before. Id give it a day or so, then time for replacement.
Anyone......anyone....... Anyone....
Yeah, could be a bad actuator which is a dealer specifc part. Could also be (but less likely) moisture in the plug that goes from the door to the door jam.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kchungb17a »</TD></TR><TR><TD CLASS="quote">Yeah, could be a bad actuator which is a dealer specifc part. Could also be (but less likely) moisture in the plug that goes from the door to the door jam.</TD></TR></TABLE>
I thought so too, but this has been happening over a month+ now...
Unless some sort of grease is stuck in thurrrr...
That's what it does when it starts to go out. It can be good for weeks then act up again, then be good for a while again (used to change them for a living)....
zach1288
Feb 6, 2007 08:34 AM
01PYTypeR#1140
Apr 29, 2002 03:36 PM
