crackling noise when putting stress on acceleration?
Old Apr 16, 2005 | 12:56 AM
Nin2lude's Avatar
Default crackling noise when putting stress on acceleration?
sounds like there is a buch of stuff rattling around in my engin when i try and step on the gas in first or second from about 10mph sounds like the car is going to die like when you run out of gas.
new sparkplug wires.... just had valvs adjusted and lash adjusted...
ohh and i blew my damm speed sensor tooo anybody know what its going to cost to fix the gear in the tranny that the speed sensor reads?
Old Apr 16, 2005 | 04:31 AM
chandler's Avatar
are you sure you are getting enough fuel? might be some knock, as for the tranny, Im not sure man, if it was a 240 I could help ya but not on a honda yet
Old Apr 16, 2005 | 02:13 PM
Nin2lude's Avatar
Default Re: (chandler)
bump for the help please... went to 5 places today including gushi racing and they dont like honda's :{ they are too much into drift cars to help me.
Old Apr 16, 2005 | 09:06 PM
Nin2lude's Avatar
Default Re: (Nin2lude)
really need help on this guy's anybody know?
Old Apr 17, 2005 | 12:39 AM
JDM Element's Avatar
umm
Do you mean pinging? What you described sounds like pinging
premium unleaded usually takes care of that, otherwise you'll have to the timing done.
Old Apr 17, 2005 | 12:28 PM
Nin2lude's Avatar
Default Re: (JDM Element)
i live in ca so our prem is only 91 not 93 :{ and ya it sounds like crap like somebody tossed a bunch of sand in the engin.
Old Apr 17, 2005 | 02:06 PM
2gn9gencevg's Avatar
My cars sounds like that too, but mine does it only when in gear so I belive mine problem is transmission related.
Your problem may also be transmision related which would explain why your speed sensor is also not working.
I'm currently looking for a good price on a used front clip.
Old Apr 17, 2005 | 07:32 PM
Nin2lude's Avatar
Default Re: (2gn9gencevg)
Old Apr 18, 2005 | 03:38 PM
Nin2lude's Avatar
nobody can help with this?
Old Apr 18, 2005 | 04:17 PM
five-0's Avatar
Try retarding your timing a bit....???? What's it at now?
Old Apr 18, 2005 | 07:48 PM
Nin2lude's Avatar
Default Re: (five-0)
its already retarted a bit... it was retarted more but the car ran sluggish... maby ill try going back one degree see how that works.
Old Apr 19, 2005 | 06:01 AM
2lude4u's Avatar
I'm experiencing the same thing. Unfortunately my head gasket didn't seat right, so I'm not driving it and thus unable to completely diagnose the problem.
This I do know though:
I had my tranny rebuilt because I thought it was a tranny bearing. They found a bad needle bearing, so I thought problem solved. I put the tranny in and it still does it and my VSS is no longer working (it was before the rebuild), so I pull out the VSS to discover it's in 3 PIECES. The shaft that the gear is on broke (I assume that's what broke first to cause the initial problems) then the outer shell broke too. Luckily I had a spare, so I put it in, speed readings are back, but it still does it, though not nearly as much as before. I checked the busted VSS and all the breaks match up, so I know I don't have any broken bits of VSS bouncing around in my tranny, so I'm still trying to figure out what is making the noise. For me it happens during low rpm torque pulls and high rpm acceleration.
Old Apr 19, 2005 | 04:27 PM
Nin2lude's Avatar
Default Re: (2lude4u)
see today i was going up hill and was in 4th gear and was flooring it at about 3k rpm up to 5k rpm and it did not do it all day today... parked the car for about 20 min went to work and on the freeway in 5th trying to pass a car it did it to me started making the noise again..
took the car to ammco today to look at it they are a bunch of idiots and will not give me a stright answer, said to tear it apart it would be 800 bucks.
called R1 Motor sports out off the 10 freeway and new ave and the guy there said he would do it for 450 add 20 bucks to replace clutch and 350ish for a stage 2 clutch and i would be set.
got my cousin calling a friend he knows to look at my tranny and he said 250-300 bucks but the job is labor intensive and is around 800 bucks in labor. so im all confused at what needs to be done on my tranny.
but the noise im getting in the car ramond from R1 said it was pinging and that he would check the h22 out for me to see if he could find out whats wrong with it. so i gotta go there tomorrow to find out whats the issue.
DeLSoLRo
Jun 1, 2011 08:44 PM
a2dadamm
Apr 10, 2007 07:56 AM
93CharcoalHatch
16
Jul 23, 2005 08:29 AM
Nin2lude
Apr 19, 2005 10:05 PM
