got a new motor, its slower?
Old Apr 15, 2005 | 10:36 PM
honda_S's Avatar
Default got a new motor, its slower?
i blew my old y8 it had like 85k miles on it, and i put one in that has 55k miles with a new timing belt a new water pump. and all that now it feels slower and it sound alot deeper throated, but on the highway it barely picks up, it used to be so much faster. anyone have an idea of whats wrong with it. BTW they are both completely stock
Old Apr 15, 2005 | 10:38 PM
handa's Avatar
Default Re: got a new motor, its slower? (8y61d)
it barely picks up hmm? check compression on the new motor. how's the throttle response?
Old Apr 15, 2005 | 10:44 PM
honda_S's Avatar
throttle response sucks ***. i put my knn on it to see if its just beeing suffacated(sp?) but it didnt do ****
Old Apr 15, 2005 | 11:05 PM
honda_S's Avatar
Old Apr 15, 2005 | 11:08 PM
Neighborhood Superstar's Avatar
barely picks up because it's still a sohc
Old Apr 15, 2005 | 11:10 PM
honda_S's Avatar
ya thanks
Old Apr 15, 2005 | 11:19 PM
GdmLaz's Avatar
hows the timing you sure it came out good....... also do a compression test see how this motor is
Old Apr 15, 2005 | 11:29 PM
honda_S's Avatar
would the timing even have anything to do with it. its not miss fireing or nothing it starts fine it idles fine. acceleration and therottle response sucks.
Old Apr 16, 2005 | 12:20 AM
knockout's Avatar
sorry its kinda off topic, but how'd your y8 blow with only 85k miles? did u rev to like 12k rpm for like a whole hour?
Old Apr 16, 2005 | 12:30 AM
Jorsher's Avatar
lol yeah good question knockout, I've never heard of a Honda engine blowing that soon, what did you do? I accidentally ran mine 800 above the redline for around 5-10 minutes going over 100 in 3rd gear on my engine with over 126,000 and it runs perfectly fine. (Although I no longer drop from 5th to 3rd at over 90)
Old Apr 16, 2005 | 12:31 AM
jessemarCc's Avatar
yeah, id check the timing first. thats how my homeboys car first felt when he swapped.
Old Apr 16, 2005 | 04:57 AM
mawkiemarc's Avatar
did the person or people u bought it from run any kind of checks, warranty? if not do a lil tune up yourself. i had the same problem about 2 weeks ago. i towed it to my shop and changed plugs, wires, belts, cap, and rotor button along with an oil change. so do lil stuff and see how it comes out....good luck
Old Apr 16, 2005 | 04:58 AM
AbitAvenger's Avatar
you did drop a Y8 in it and not another engine right? Does it have the same tranny as before? That could make a difference.
Old Apr 16, 2005 | 05:24 AM
civic2slo's Avatar
You mentioned you changed the timing belt. Make everything lined up (all your marks). Next have you timing checked. Check your firing order (I know I'm just covering all the bases). Did you engine come with a catalytic converter? Make sure its not clogged. Thats all I can think of this early in the morning
Old Apr 16, 2005 | 05:53 AM
-[95cxhatch]-'s Avatar
Default Re: (8y61d)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 8y61d &raquo;</TD></TR><TR><TD CLASS="quote">would the timing even have anything to do with it. its not miss fireing or nothing it starts fine it idles fine. acceleration and therottle response sucks. </TD></TR></TABLE>
Old Apr 16, 2005 | 06:11 AM
pdiggitydogg's Avatar
Check the timing. Check the compression.
Was it just the bottom end you replaced?
Old Apr 16, 2005 | 07:50 AM
honda_S's Avatar
i blew it on the freeway. i had it in 4th at like 120+ for a while. oops! anywase it was a full long block swap. i just bought the transmission like 4000 miles ago so i had them keep it on there.
the engine was suposed to be tested it has a 90 day warrenty. im taking it in monday cuz they took my face to my radio
Old Apr 16, 2005 | 09:07 AM
BauleyCivic's Avatar
Risky Business
Default Re: (8y61d)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 8y61d &raquo;</TD></TR><TR><TD CLASS="quote">i blew it on the freeway. i had it in 4th at like 120+ for a while. </TD></TR></TABLE>
Old Apr 18, 2005 | 03:57 PM
mawkiemarc's Avatar
AMEN!!!!!...............
Old Apr 18, 2005 | 04:01 PM
airplan727's Avatar
Timing can have everything to do with it. If the spark is not sparking at the right time (top of the compression stroke) you don't get the ideal detonation and loose power. Are you sure the engine you got was in good shape, if timing isn't the issue?
Old Apr 18, 2005 | 04:04 PM
honda_S's Avatar
he told me my compression is 150 all 4 cylinders and its normal( i dont think its normal) i made another thread on it. im going to test the compression my self and see what happens.
my question is am i fucked if the compression is low
Old Apr 18, 2005 | 04:06 PM
thehatchninja's Avatar
IGNITION TIMING!!!!!!
common problem....my gsr swap was slower than my old z6, set the timing, and now it pulls hard as a ****
Old Apr 18, 2005 | 04:07 PM
airplan727's Avatar
I'm not sure for Civics, but for Integras 135 is minimum and they are higher compression. If they are low then the engine would have to be rebuilt to bring it a significant amount back up. Check the timing though. Just make sure it isn't to far advanced or to far back. How is the spark and all that stuff. Sometimes a good tune-up can give a car a good amount of power back.
Old Apr 18, 2005 | 04:18 PM
NineTwoSi's Avatar
Default Re: (AbitAvenger)
AbitAvenger your avatar should be the only one available to trial users!
buster1395
Jun 26, 2011 07:20 AM
Midori Green
Oct 18, 2008 05:44 PM
Scrapin4DR
May 5, 2008 06:33 PM
envision
Feb 4, 2008 02:41 PM
Mr.Luder
Mar 15, 2007 03:38 AM
