h22 syncro rings and slevves the same as h23
i can pilage an h23 for parts and i need to replace all the syncro rings ,sleeves and othe misc parts...i would imagine they would be close as only the gear ratios them selves should be differrtn
thanks guys
im on a super budget so that why im gonna do it this way first...ill save up for new parts over the summer
thanks guys
dam.....well its a start any way i look at it ...
to use the h23 5th gear i need both the counter shaft 5th and mian 5th ..right
if worst comes to worst mabye ill just put the h23 in there now till i get more money
did some cross referencing on majestic today and found most the parts i need are the same
hubs ,synro rings,sleeves and syncro springs..
eddie im not sure ion the 3rd gear thing caus eth eparst are only listed as a gear set on both trannies ..and with 3rd being differetn of course they have a dif part number
but i iwll keep an update if anything changes
eddie you were right about the 3rd and 4th syncro set are not the smae
the h23 is smaller then the h22 and wont fit ..so mine had to do ..
i ended up changing the 1/2 synros,sleevs and hubs
3rd and 4th had to stay (not in to bad of shape....i did use the h23 sleeve ..crap i think i did lol
swaped the whole 5th gear set from th h23 since mine was toast......all went to gether pretty good ..
took 2 and a half hours to tear them both down and reassembly the h22 tranny
Sounds like you have a handle on it. Did I read right or did you say that you put the H23 fifth gears in yout M2F4 transmission? So you have a lower cruising rpm in 5th?
Pirate
Pirate
yea i my 5th was so far gone it didnt even grab..just sliped ..so instead of buying a 300 dollar gear set i just used the 5th from the h23 .it was in great shape .(dont worry i took the 5th from the countershaft as well lol)
i did use the hub and sleeve from the 3/4 since mine was gound down a lot but the syncros them selves wouldnt not fit
im still wondering if i should buy the new 5th gear shift fork....the h23 had no signs of grinding and im thinking i might just use it ...or spen the 65 bucks to get the new one that is fixed supposidly
i also had to use the counter shaft from the h23 as my h22 had a nasty casting flaw right in the bearing area.....no wear but just a hole almost
Modified by machine4321 at 11:47 AM 4/19/2005
Modified by machine4321 at 11:50 AM 4/19/2005
