Mileage problem
Old Apr 15, 2005 | 06:45 PM
dtamminx's Avatar
Default Mileage problem
Hi, I am having problem with gas mileage, I get only 20-22 miles max per gallon even on highway.
What should I do to get better mileage.
Its 99 Accord EX
Thanks in advance,
DT.
Old Apr 15, 2005 | 08:17 PM
wragen22's Avatar
I get about 25. 70mph freeway.
Old Apr 15, 2005 | 08:29 PM
Schmitey's Avatar
Default Re: (wragen22)
spark plugs, wires, run injector cleaner through it, air filter, run sea foam through the intake
check your tire pressure too, that can have a big influence on gas mileage...AC hurts it too
Old Apr 16, 2005 | 07:32 AM
dtamminx's Avatar
Default Re: Mileage problem (dtamminx)
Has anybody tried Fuelmiser or Turbonater?
Thanks
Old Apr 16, 2005 | 08:35 AM
90accorddx's Avatar
that turbonator is a crock of **** all that is something that is supposed to be in a boat that just happens to fit in the intake tube doesnt work
Old Apr 16, 2005 | 10:07 AM
Bishop Don Shizzle's Avatar
Oh yeah I forgot I can edit my own title! Yay!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dtamminx &raquo;</TD></TR><TR><TD CLASS="quote">Hi, I am having problem with gas mileage, I get only 20-22 miles max per gallon even on highway.
Its 99 Accord EX
Thanks in advance,
DT.</TD></TR></TABLE>
Check your tire pressure, clean out your injectors, check your air filter, basically just do a thorough check of your car and make sure everything's okay.
When was the last time you changed your oil?
Old Apr 16, 2005 | 04:25 PM
YeuEmMaiMai's Avatar
If you milage is that bad, I would check out the following sensors
1. O2
2. Engine coolant Temp
If they check out, check for a leaking inejector. your Vss may be bad (are your RPMs higher than normal)
do you have a fuel leak?
Old Apr 16, 2005 | 08:14 PM
dtamminx's Avatar
Default Re: (YeuEmMaiMai)
I am pretty sure there are no leaks. Would get O2 and coolant temp checked out. Would also try sea foam.
Thanks.
howard-zhang
Jan 1, 2009 07:49 PM
refman102
Feb 12, 2007 04:23 AM
colslaw87
Oct 26, 2004 06:11 PM
zman1618
May 8, 2004 06:33 PM
Yyz
Jun 13, 2003 01:56 PM
