Axle Replacement
Old Apr 15, 2005 | 06:40 PM
ExiledinIN's Avatar
Default Axle Replacement
I swapped in my B18C last summer and got to thinking. When I put the axles into the diff, did I have to grease the spline? Or does it fit in dry?
Old Apr 15, 2005 | 06:44 PM
TeamNextGenChris's Avatar
Default Re: Axle Replacement (ExiledinIN)
it will fit in dry,but i always put a little grease on the splines to ease the insertion....err,did that sound weird?
Chris
Old Apr 15, 2005 | 07:06 PM
ExiledinIN's Avatar
Default Re: Axle Replacement (TeamNextGenChris)
Easy now, Roanoke's a great place!
Thanks, but it went in real easy w/o any grease, but wondering if that will hurt long term???
Old Apr 15, 2005 | 07:08 PM
litterbox's Avatar
I am a (Trial User) Army
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamNextGenChris &raquo;</TD></TR><TR><TD CLASS="quote">it will fit in dry,but i always put a little grease on the splines to ease the insertion....err,did that sound weird?
Chris</TD></TR></TABLE>You *****
When I replaced my broken one I didn't put any grease? I'd like to know if it'll hurt long term as well.
Old Apr 15, 2005 | 07:24 PM
Default Re: Axle Replacement (litterbox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox &raquo;</TD></TR><TR><TD CLASS="quote">You *****
When I replaced my broken one I didn't put any grease? I'd like to know if it'll hurt long term as well.</TD></TR></TABLE>
it will be fine,just keep it in mind for future use.also,it helps to put a little grease or antiseize on the outer splines that slide into the hub-makes it MUCH easier to remove the axle later on.it makes the difference in having to use an air hammer to get it out,or being able to push it out with your fingers.
Chris
Old Apr 15, 2005 | 07:43 PM
civic94B18B1's Avatar
That's not a big deal.Just gonna make it a little harder for you.I've personally done at least 25 CV joints and never lubed one. In addition i'm in honda PACT and never did it in there either.
bobaloo27
Jan 14, 2006 10:44 PM
hondapwr
26
Apr 10, 2005 07:13 PM
Ideal
Apr 5, 2005 11:40 PM
InfamousGSR
Apr 16, 2004 10:17 AM
wm5holla
Oct 8, 2003 01:47 PM
