Tire Pressure??
It may be a dumb question, but I move from my stock 14's to new 15's. 205/15/45's. How do I know what should be the "right" air pressure. Stock tires I just chec that sticker on the door...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ExiledinIN »</TD></TR><TR><TD CLASS="quote">Anyone know???</TD></TR></TABLE>
There are plenty of places online (The Tire Rack) where you can check and see what you should have your tires inflated to. Every type of tire will be different, and so will every person. What I mean by that is that I usually keep mine inflated to 32 PSI but if I know I'm going to be beating on it a little bit, I'll lower the pressure to like 29 or 30 PSI so I can get some more contact
Hmm, looked all over tirerack.com and couldn't find it. On discounttire.com, they just said to stop by and they have a copy of the tire load/inflation tables. I couldnt' even locate a table on Yokohama's site either.
The pressure recommended by your car's manufacturer (in the owner's manual and/or the door jamb sticker) is a good place to start. Try it. If you find that you need to change it, then do so - either to adjust the handling, or due to uneven tire wear (more wear in the center than both edges is a sign of overinflation, and more wear on both edges than in the center is a sign of underinflation).
sporty240
23
Aug 25, 2005 06:25 AM
