B series EF's (Tranny removal ?)
Can you pull the tranny out without removing the engine if you have hasport mounts?I need to pull my tranny and it looks tight so I was wondering if it could be done wihout removing everything?
Yes it can be done.
Place a jack with a wood block under your oil pan for support.
Disconnect the tranny mount.
Lower the motor (it will tilt)
Remove the tranny
Remove the tranny
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XtraFastCRX »</TD></TR><TR><TD CLASS="quote">one tip to remove the tranny after all the bolts are off is to push the clutch in and the tranny will seperate... </TD></TR></TABLE>
Too bad I cant do this........ I could damage my throw out bearing.
remove the bolt for the tranny mount, i had to remove my radius rods,
when i was putting mine back on i was refusing to take the tranny mount off the tranny because i didnt think i would be able to get it back on once the tranny was stabbed. If you remove the battery tray you will have plenty of room .
0ptimus prime
Jun 27, 2004 12:12 PM
