need help with shock cap removal. pix included
Old Apr 15, 2005 | 04:34 PM
digitalh3lix's Avatar
Default need help with shock cap removal. pix included
Alrite... heres the deal.. i took my whole shock/spring assembly out of my 4th gen lude today.. about to do some spring upgrades. the thing is i cant take the cap off the top of the shock off. am i suppose to break those 2 bolts apart? and what kinda if tool is thin enough to do it. i went to autozone, lappens, ace hardware, and home depot. no luck. any suggestions on how to take the cap off the top?
::edit::
each bolt is like 2 quaters stacked thick. and the open wrenchs are too thick to hold just 1. i've tried.
Old Apr 15, 2005 | 04:48 PM
five-0's Avatar
Default Re: need help with shock cap removal. pix included (digitalh3lix)
Try Sears. There should be some thin craftsman wrenches you can get your hands on. Or else get some cheapies and grind'em down until they are thin enough to work.
Old Apr 15, 2005 | 07:48 PM
BB4's Avatar
BB4
whats the probelm with removing them one by one?
Old Apr 15, 2005 | 08:21 PM
OaksRacing's Avatar
Default Re: (bb4)
Hold the area just above the treads with vice grips and only loosen the top nut. Be careful not to get into the treads.
Old Apr 15, 2005 | 09:37 PM
Default Re: (bb4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bb4 &raquo;</TD></TR><TR><TD CLASS="quote">whats the probelm with removing them one by one?</TD></TR></TABLE>
the problem is the whole top part spins with it. and you cant spin both of them at the same time.
Old Apr 15, 2005 | 10:26 PM
98TypeSH's Avatar
Default Re: (digitalh3lix)
use a pair of vice grips to hold the very end above the threaded part. then try and get a 12 point closed end on the top nut and crank it with all u got.
Ahh Oaks beat me to the punch. damn me and not reading.
Old Apr 15, 2005 | 11:53 PM
Eddiebx's Avatar
i say screw the vise grips and just hit it with an impact wrench, less chance of damage that way, plus a **** load easier
Old Apr 16, 2005 | 05:58 AM
clemsoncb7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by digitalh3lix &raquo;</TD></TR><TR><TD CLASS="quote">
the problem is the whole top part spins with it. and you cant spin both of them at the same time.</TD></TR></TABLE>
Bud, Look at the top of the strut, there is a hole made for an allen wrench. YOu hold the whole assembly with that allen wrench then use regular wrenches for the nuts holding on the pillow mount. Vice grips will strip the threads. Or if you can get your hands on an impact wrench that works too, but that top part is ment for an allen wrench!! Let me know how it works!
Old Apr 16, 2005 | 09:03 AM
LudeyKrus's Avatar
Default Re: (maxvtec7500)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maxvtec7500 &raquo;</TD></TR><TR><TD CLASS="quote">
Bud, Look at the top of the strut, there is a hole made for an allen wrench. YOu hold the whole assembly with that allen wrench then use regular wrenches for the nuts holding on the pillow mount. Vice grips will strip the threads. Or if you can get your hands on an impact wrench that works too, but that top part is ment for an allen wrench!! Let me know how it works!</TD></TR></TABLE>
It looks like he's running Koni Yellows; in place of that allen-head hole, there's a spinning flat tab that's used for adjusting the dampening of the shocks. Using an allen-head wrench is not an option for him.
There's three things I would try:
1 - Use an impact wrench w/ a deep-well socket and sit the socket on just the top nut, then hit it hard.
2 - If you can't get ahold of an impact wrench, try taking a deep-well socket and put it over the top nut and smack the wrench. it may be enough to knock the top one loose.
3 - Can't get it yet? Take a set of vice grips and clench them on the part right above the threads above the lock-nuts, then use a hand wrench to get the nuts off....just like Oaks said.
Old Apr 16, 2005 | 09:25 AM
clemsoncb7's Avatar
Default Re: (LudeyKrus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeyKrus &raquo;</TD></TR><TR><TD CLASS="quote">
3 - Can't get it yet? Take a set of vice grips and clench them on the part right above the threads above the lock-nuts, then use a hand wrench to get the nuts off....just like Oaks said.</TD></TR></TABLE>
Good call, I just noticed the yellow shock body, then yes, used a deep-socketed impact wrench!
Old Apr 18, 2005 | 11:16 AM
no luck with the impact wrench.. any other suggestions?
Old Apr 18, 2005 | 01:45 PM
chitownrida's Avatar
if the shock body is still spinning.. uncompress the spring so its loading the hat. then use your socket and ONLY loosen the bolts up. that usually works.
**very important**
then compress the spring before you pop off the hat
tazeat
28
Mar 4, 2008 12:48 PM
Arturbo
Mar 13, 2007 04:55 PM
digitalh3lix
Suspension & Brakes
13
Apr 22, 2005 07:33 AM
seeeya04
Suspension & Brakes
10
Jan 16, 2005 06:24 PM
MachAF
Mar 23, 2003 08:20 AM
