those of you who have rear disc conversions... of knowledge of
Old Apr 15, 2005 | 03:24 PM
idriveadelsol7's Avatar
Default those of you who have rear disc conversions... of knowledge of
94 del sol S.
yes... i know. i searched and dude... i'm more confused now than before. i have everything: integra trailing arms, upper and lower control arms...
here's the part where i'm not to sure about. i need all the cables. they've all been cut. now which 1's do i pick up? and as for bushings, they all seem to be torn. what bushings do i need? can somebody help me out as to what parts i need before i attempt to try DYi this?
Old Apr 15, 2005 | 03:31 PM
skater5067's Avatar
Default Re: those of you who have rear disc conversions... of knowledge of (deLasoL7)
https://honda-tech.com/zerothread?id=642479 go ther and look on the faq's helped me tons
Old Apr 15, 2005 | 03:37 PM
dohcbag's Avatar
Default Re: those of you who have rear disc conversions... of knowledge of (skater5067)
kinda OT, but i would never buy an "emaculate" engine.
immaculate.
Old Apr 15, 2005 | 04:09 PM
Default Re: those of you who have rear disc conversions... of knowledge of (dohcbag)
haha thanks for the bump i'll change it spelling BeEeEE champion
Old Apr 15, 2005 | 04:11 PM
i've read all of them... they say integra.... another says civic si. and 1 says del sol si-vtec. and i'm lost. i'm guessing they're not all the same.
Modified by deLasoL7 at 5:25 PM 4/15/2005
Old Apr 15, 2005 | 04:42 PM
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
If u have a delsol, then go with the delsol vtec cables. Integra may work, but may be too long, I'm not sure. I have an EK 4 door and i'm running integra 2 door on it right now, it works fine
Old Apr 15, 2005 | 05:01 PM
pdiggitydogg's Avatar
Get cables that are best fit you your chassis. You want Del sol Si or Del Sol vtec.
Integras will be too long for you
You dont need lower control arms - you will be using the ones that came on the car.
Old Apr 15, 2005 | 05:17 PM
Default Re: (pdiggitydogg)
the reason i want to use the control arm is because the del sol S control arm doesn't have a spot i can bolt an aftermarket sway bar onto.
anyway so as for cables:
i need 1 for the e-brake correct? and 2 other ones because i read somewhere it's seperated- like this 1RL, 1RR (2 rears). 1FR, 1FL (2 fronts)?
would i have to upgrade the MC / booster / prop valve ?
Modified by deLasoL7 at 6:27 PM 4/15/2005
Old Apr 15, 2005 | 05:28 PM
you need 1 cable for each wheel = 2 cables
you also need rear disc brake hoses = 2 (this is the rr,rl but theyre nonspecific for the sides)
You do want a prop valve (get one from a del sol si since its for your chassis and is non-abs)
An upgraded mc/bb is recommended
Those 2 you really should have found by searching.......
Old Apr 15, 2005 | 05:30 PM
AzntaggeR's Avatar
TSPeed Factory
you need del sol si/vtec e-brake cables. integra ones are a bit different.
Old Apr 15, 2005 | 05:38 PM
92b16vx's Avatar
Yes, use the DelSol parts, the Civic/Integra ones don't fit (ebrake cables). For the fluid lines, almost anywill work, as long as they came form a rear disc model. You can get away without replacing the MC and PV, but it is recommended.
Old Apr 15, 2005 | 05:39 PM
i read that the prop valve/mc/bb are not required... what exactly do each of those do? haha
i called sparks racing and their mechanic told me that all i would need is the e-brake cable. my eyes hurt.
Old Apr 15, 2005 | 05:43 PM
92b16vx's Avatar
Must haves= Delsol ebrake cables, rear disc fluid lines.
recommended= PV and MC booster combo.
I have some Delsol rear disc ebrake cables in my basement if you need them, PM me.
Old Apr 15, 2005 | 05:51 PM
Default Re: (92b16vx)
i'm ready to go...
my pms suck. get on your aim Lo0kitsdavid
Modified by deLasoL7 at 7:24 PM 4/15/2005
Old Apr 15, 2005 | 06:06 PM
AzntaggeR's Avatar
TSPeed Factory
Default Re: (deLasoL7)
its a pretty easy swap dude. i've done this very same swap and it was pretty straight forward.
Old Apr 15, 2005 | 06:08 PM
Default Re: (AzntaggeR)
i hope... anybody got part #'s as to which cables (3 total) i need? i don't want to place the wrong order ah
Old Apr 15, 2005 | 06:09 PM
jdmd15b's Avatar
ok so not too mant ppl seem to realize this but the master cyl. is the same for the early integra's, del sol's and civics (and the non vtec accords). enev though part numbers may vary, even with the same brand, they are essentially the same, so forget that. you dont NEED the porportioning valve, but without it the pedal will have alot more travel than your used to, and with it the performance is alot better because with rear disk, more power is sent evenly, as with drums the front do most of the work. now as for the power booster, that is different (widely) between models, for best performance i would go with the gsr booster, youll stop on a dime, but any vtec performance honda or acura booster will be sufficient. the cables also vary (again, widely) between the models, you will need del sol cables, i have a pair for sale if you need them, i bought a conversion off ebay for almost nothing cause it was off of a del sol and put it on my eg, but the cables it came with are far too short for me. sorry i tend to ramble but oh well
AzntaggeR's Avatar
TSPeed Factory
order from http://www.hondaautomotiveparts.com
Old Apr 15, 2005 | 06:24 PM
105043 005 1 PIPE C, BRAKE
105046 006 1 PIPE D, BRAKE
right? where is the ebrake cable.
Old Apr 15, 2005 | 06:35 PM
BlueIntegraBoy's Avatar
https://honda-tech.com/zerothread?id=1198300
Old Apr 15, 2005 | 06:37 PM
rukawa1one's Avatar
actually the prop valve is neccessary, the bb and mc aren't, but recomended
Old Apr 15, 2005 | 06:43 PM
jdmd15b's Avatar
Default Re: (rukawa1one)
its isnt a must but the pedal will have more travel, i ran for a month without one, but what do i know, ive only been a mechanic for 5 years. dont mean to argue, everyone is intitled to thier own opinion, even if its wrong
Old Apr 15, 2005 | 07:03 PM
Default Re: (BlueIntegraBoy)
you have the diagram of that...?
Old Apr 15, 2005 | 07:10 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deLasoL7 &raquo;</TD></TR><TR><TD CLASS="quote">you have the diagram of that...?</TD></TR></TABLE>
diagram of what?
Old Apr 15, 2005 | 07:13 PM
those parts
