getting off the front disc
Old Apr 15, 2005 | 01:44 PM
ironryder's Avatar
Default getting off the front disc
trying to get my front rotor off but that two X screws are so hard to turn.Anyone know an easy way to get those screws off the front rotor??(with out killing the screws thanks
Old Apr 15, 2005 | 01:47 PM
SOHC4life 96's Avatar
Default Re: getting off the front disc (ironryder)
$25 at sears.
http://www.sears.com/sr/javasr...41000
Old Apr 15, 2005 | 01:55 PM
vtec y0's Avatar
Default Re: getting off the front disc (SOHC4life 96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC4life 96 &raquo;</TD></TR><TR><TD CLASS="quote">
$25 at sears.
http://www.sears.com/sr/javasr...41000</TD></TR></TABLE>
Old Apr 15, 2005 | 02:07 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: getting off the front disc (vtec y0)
if you didnt know what it was called it is an impact driver. you turn it in the direction you want the screw to go, then you hit it with a hammer.
Old Apr 15, 2005 | 02:27 PM
B18Cej1's Avatar
Default Re: getting off the front disc (boostedcivicsir)
u could use a chisel and hammer.. but i would go with the impact driver
Old Apr 15, 2005 | 03:43 PM
vtec y0's Avatar
Default Re: getting off the front disc (B18Cej1)
or u can use a impact with a bit. Make sure u dont strip it
Old Apr 15, 2005 | 04:05 PM
GoodEyeSniper's Avatar
86%
when I was changing my front disks I noticed the two screws were pretty fouled up. One looked like someone nearly stripped the head, then sautered some metal into it filling it up so you can't get a screwdriver to bight the screw... Anyone know what could have caused that?
Old Apr 16, 2005 | 03:44 PM
ironryder's Avatar
Anyone know if those two X screws are dealers item only or can be find in parts store??
Old Apr 16, 2005 | 03:53 PM
DC4noMore's Avatar
Default Re: (ironryder)
you dont need to reinstall the screws when you put your rotors back on. They are only there to hold them on during assembly.
Old Apr 16, 2005 | 05:34 PM
B18Cej1's Avatar
Default Re: (DC4noMore)
if u really want to get them, u can go to the dealership
Old Apr 16, 2005 | 05:38 PM
kkim's Avatar
Default Re: (B18Cej1)
If the screw heads are really bad, you can use a drill bit to drill the top of the screw off. Take the rotor off, then use channel locks or vise grips to grab ahold of the screw body to remove.
MDM
Jun 16, 2007 03:42 PM
