how can u tell if u spun a bearing
Old Apr 15, 2005 | 12:57 PM
allnapower's Avatar
Default how can u tell if u spun a bearing
mechanic says he thinks i spun a bearing in my b20 block how can i tell if hes right, or what does that mean or anything
Old Apr 15, 2005 | 01:03 PM
onepoint6i's Avatar
Default Re: how can u tell if u spun a bearing (fastcarsRlife)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastcarsRlife &raquo;</TD></TR><TR><TD CLASS="quote">mechanic says he thinks i spun a bearing in my b20 block how can i tell if hes right, or what does that mean or anything</TD></TR></TABLE>
youll hear a ticking/knocking sound at first then it'll get louder and louder in sound..especially when at high revs..or you can pull the pan and couple if not all of the bearing caps to see ..
Old Apr 15, 2005 | 05:01 PM
topspeed86's Avatar
If your motor starts pull the sparkplug wires one at a time if the noise stops you will know what cylinder is spun, or pull your oil pan and look for metal shaving's in the pan
Old Apr 15, 2005 | 05:28 PM
drdisco69's Avatar
Default Re: how can u tell if u spun a bearing (topspeed86)
Blue or black rod caps or main caps, lower oil pressure, or an oil analysis can tell you what metals are in your oil. Lots of copper = bearings.
If you really don't know what he's talking about, maybe you should have someone else verify it with you. Do you have any reason to think he's not telling you the truth?
Old Apr 16, 2005 | 09:00 AM
allnapower's Avatar
Default Re: how can u tell if u spun a bearing (drdisco69)
na i know what hes talking about nevermind
preludeNApower
Aug 1, 2014 09:55 PM
D16Y8-JDMYO
Oct 22, 2006 04:02 PM
gsr_b20x2
Oct 4, 2005 08:05 AM
pyromaster
Mar 2, 2005 12:04 PM
espanol
Apr 20, 2003 10:04 AM
