(searched) Slave cylinder install
Old Apr 15, 2005 | 12:51 PM
Brycen's Avatar
Default (searched) Slave cylinder install
Hey guys just wondering on an F22B1 slave cylnder install hard or easy, and what would it take to do it?Should just be an unbolt and then bolt on or do you have to do somehitng else for it,mine is leaking therefore i need to replace it.And also does 30 dollars for a Slave cylinder sound like a good price or too cheap? It is from Schucks.
Old Apr 15, 2005 | 01:40 PM
SearchBeforeUPost!'s Avatar
Default Re: (searched) Slave cylinder install (Brycen)
$30 is about right, the install is not hard. The slave cyl is on the front of the trans, just undo the fitting, take two bolts out, and take it out. Reinstall and bleed the clutch.
Old Apr 15, 2005 | 01:56 PM
Brycen's Avatar
Default Re: (searched) Slave cylinder install (SearchBeforeUPost!)
It shouldn't be hard to repressure the clutch peddle should it?
Old Apr 15, 2005 | 04:34 PM
-Bionic-'s Avatar
Former Sponsor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Brycen &raquo;</TD></TR><TR><TD CLASS="quote">It shouldn't be hard to repressure the clutch peddle should it?</TD></TR></TABLE>
Just need to bleed the clutch. Would help tremendously if there were two people working together. 30 dollars sounds cheap. I got mine for 60 at the dealer.
soon2bdropped
Jun 28, 2006 02:42 PM
turboME
Jun 26, 2006 06:24 PM
tegon-gsr
Feb 29, 2004 02:13 PM
The Acclude v 2.0
Jun 21, 2003 11:01 AM
