msd install help
Old Apr 15, 2005 | 11:31 AM
v.i.gsr's Avatar
Default msd install help
I just bought a msd digital sci from summit, and I installed it in my swapped ek hatch, and now my car won't start. I hooked it up the same way I read it in the instruction manual,from various searches I looked up here on h-tech,I also looked @ the how to on c-speedracing.com. Everything is hooked up correctly. I checked,double checked, and triple checked and the car still wont start. It just cranks and won't turn over. DO you guys think I need the tach adapter from msd.What do you guys think can be the problem.PLEASE HELP ME OUT. my swap is a b18c1 in a 1997 cx hatchbatch
Old Apr 15, 2005 | 03:14 PM
skunked's Avatar
Default Re: msd install help (v.i.gsr)
are you running the internal or external coil?
Old Apr 15, 2005 | 03:52 PM
v.i.gsr's Avatar
Default Re: msd install help (skunked)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked &raquo;</TD></TR><TR><TD CLASS="quote">are you running the internal or external coil?</TD></TR></TABLE> I'm running an internal coil
Old Apr 16, 2005 | 05:39 AM
v.i.gsr's Avatar
helloooooooooooooo!!!! anybody out there.
Old Apr 16, 2005 | 10:13 AM
skunked's Avatar
I would check to make sure you hooked the coil up correctly. Are you using the 12V and ground on the battery for the MSD box?
Old Apr 16, 2005 | 04:10 PM
v.i.gsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked &raquo;</TD></TR><TR><TD CLASS="quote">I would check to make sure you hooked the coil up correctly. Are you using the 12V and ground on the battery for the MSD box?</TD></TR></TABLE> yes i am
Old Apr 16, 2005 | 04:25 PM
EJtypeR's Avatar
check for spark. if you have spark throught your wires then your plugs are wrong. i had that problem. you cant run platinum plugs with msd. only <U>copper core plugs</U>
Old Apr 16, 2005 | 06:54 PM
v.i.gsr's Avatar
Default Re: msd install help (EJtypeR)
I am running platinum plugs. i'll change them and try again. Also would the plug wires have something to do with the car not starting.Msd says you have to use heli-core wires.
Old Apr 16, 2005 | 07:29 PM
v.i.gsr's Avatar
do you guys think I also need the tach adapter, or is it not needed.
Old Apr 16, 2005 | 07:54 PM
dunkd's Avatar
tach adapter is not needed...
check to see if you are getting spark. unplug one of the spark plug wires from the spark plug and stick a screwdriver in it. lay it over something metal in the engine bay, but not touching it, and have someone crank over the motor. you should see the spark jumping from the screwdriver to the metal.
if you can see the spark jumping then your msd is installed right. problem lays elsewhere.
Old Apr 17, 2005 | 08:23 AM
v.i.gsr's Avatar
Default Re: (dunkd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dunkd &raquo;</TD></TR><TR><TD CLASS="quote">tach adapter is not needed...
if you can see the spark jumping then your msd is installed right. problem lays elsewhere.</TD></TR></TABLE>
did that and there is spark,could be a problem with the msd, because i put it back stock and the car started right up.
Old Apr 17, 2005 | 08:40 AM
skunked's Avatar
Default Re: (v.i.gsr)
Did you cut the loops on the box? I know allot of people forget about that on the other box's but I'm not sure if the SCI box has them.
Old Apr 17, 2005 | 10:05 AM
v.i.gsr's Avatar
Default Re: (skunked)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked &raquo;</TD></TR><TR><TD CLASS="quote">Did you cut the loops on the box? I know allot of people forget about that on the other box's but I'm not sure if the SCI box has them.</TD></TR></TABLE>
no I didn't cut the loop. does that make a diffrence.
Old Apr 17, 2005 | 10:08 AM
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v.i.gsr &raquo;</TD></TR><TR><TD CLASS="quote">
no I didn't cut the loop. does that make a difference.</TD></TR></TABLE>
yep. the units usually come from the factory for 8 cylinders. Cut the first loop for a 6 cylinder and cut both loops for a 4 cylinder. Read the directions......
Old Apr 17, 2005 | 10:24 AM
v.i.gsr's Avatar
msd says for honda applications u don't need to cut the loop. I'll give it a try anyways.
Old Apr 18, 2005 | 10:56 AM
v.i.gsr's Avatar
bump
Old Apr 18, 2005 | 10:58 AM
v.i.gsr's Avatar
yep. the units usually come from the factory for 8 cylinders. Cut the first loop for a 6 cylinder and cut both loops for a 4 cylinder. Read the directions......</TD></TR></TABLE>
the digital sci only comes with one loop. msd says they come set for 4 cylinders.
Old Apr 18, 2005 | 11:00 AM
skunked's Avatar
Then I don't see what the problem is. Your sure it has power? No blown fuses?
Read through the instructions again. Something obviously isn't hooked up right.
mrnastix
10
Oct 10, 2006 05:51 AM
ganjafarmer143
17
Oct 4, 2006 03:40 AM
tuanhoprosk8
Jun 2, 2005 07:47 PM
Undercover_Skank
Sep 13, 2004 08:59 AM
batboy18
Aug 26, 2001 05:01 PM
