Erratic Idle after Intake Manifold Install
Old Apr 15, 2005 | 10:59 AM
aalb1's Avatar
Default Erratic Idle after Intake Manifold Install
I just installed a Victor X Manifold and now I'm having idleing problems.
I tried to fix it with the idle adjustment screw but it still idles high.
It stays steady at about 1300, and I can't hold it at a steady RPM of 3000 with under no load.
I don't think there is a leak b/c it seems to hold boost fine.
Any suggestions?
Old Apr 15, 2005 | 11:03 AM
gelstudios's Avatar
Default Re: Erratic Idle after Intake Manifold Install (aalb1)
if idling high, its probably the intake mani gasket (vaccum leak) , make sure you clean the head well (Get all of the old gasket off) and torque the manifold down properly.
Old Apr 15, 2005 | 11:04 AM
POE's Avatar
POE
spray carb cleaner all around the gasket on the IM and other areas u think there might be a leak.
Old Apr 15, 2005 | 11:09 AM
ssbpturbohatch's Avatar
Default Re: (POE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by POE &raquo;</TD></TR><TR><TD CLASS="quote">spray carb cleaner all around the gasket on the IM and other areas u think there might be a leak.</TD></TR></TABLE>
agreed, if the motor bogs when you do this it shows where a leak is
Old Apr 15, 2005 | 11:13 AM
Ricey McRicerton's Avatar
Default Re: (ssbpturbohatch)
Cut a small tube. Put one end of tube to ear. Move other end of tube around places where there could be a vaccum leak. It is a vaccum leak, you just need to track it down. My intake mani did the exact same thing when I had open air injection holes on a 97 y7.
Old Apr 15, 2005 | 11:22 AM
PureBlood's Avatar
stupid question, but did you reset your ecu?
Old Apr 15, 2005 | 11:46 AM
TeamNextGenChris's Avatar
the engine will still make boost,even with a pretty large leak.have you checked all the fittings on the bottom side of the mani?i had one of the plugs fall out while driving on my Victor mani.
Chris
Old Apr 15, 2005 | 01:07 PM
WestEM1's Avatar
Default Re: Erratic Idle after Intake Manifold Install (TeamNextGenChris)
while ur at it..check ur tb gasket too if ur gonna check ur IM gasket
Old Apr 19, 2005 | 06:15 AM
aalb1's Avatar
Default Re: Erratic Idle after Intake Manifold Install (WestEM1)
Thanks a lot guys...I gotta buy some carb cleaner then I'll try it out.
Whith the carb cleaner what will happen? Will it bubble? Will it get sucked up b/c of vacuum?
Old Apr 19, 2005 | 07:23 AM
DaX's Avatar
DaX
Loved
Community Favorite
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aalb1 &raquo;</TD></TR><TR><TD CLASS="quote">Thanks a lot guys...I gotta buy some carb cleaner then I'll try it out.
Whith the carb cleaner what will happen? Will it bubble? Will it get sucked up b/c of vacuum?</TD></TR></TABLE>
It will suck it in and cause a rich condition, bogging the engine.
Old Apr 19, 2005 | 07:32 AM
turboxsi's Avatar
Did you check to make sure you reconnected all the plugs correctly on the proper sensors. When i was swapping a b16 into my cx, i had accidently plugged the purge valve plug (2 pin, which b16 doesn't use) to the iacv and i got an idle that wouldn't hold steady at 3000.
But most likely sounds like vaccum leak to me, try the carb cleaner trick!
singlecammin
Jan 20, 2011 07:20 PM
SimplyTron
Jan 26, 2006 08:19 PM
snowblind7x
Oct 11, 2005 04:10 AM
98itr0448
Jul 10, 2004 03:17 PM
ULTRA911
Mar 4, 2003 10:00 AM
