type-r LSD into B16A2 -> problem
Old Apr 15, 2005 | 10:30 AM
Roky's Avatar
Default type-r LSD into B16A2 -> problem
i got a slightly used EK9 LSD directly from japan and i intended to put it into my B16A2 (1996 EK4) tranny...
now the problem is that the LSD didn't come with a ring gear... and the ring gear i had on my stock differential has a smaller inner diameter than the outer diameter of the new LSD, so it doesn't slide on the new LSD...
what should i do now? order a type-r ring gear will it fit in the B16 tranny? should i try to make the hole on the ring gear bigger? any ideas?
Old Apr 15, 2005 | 04:21 PM
smokey2.0's Avatar
Default Re: type-r LSD into B16A2 -> problem (Roky)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Roky &raquo;</TD></TR><TR><TD CLASS="quote">i got a slightly used EK9 LSD directly from japan and i intended to put it into my B16A2 (1996 EK4) tranny...
what should i do now? order a type-r ring gear will it fit in the B16 tranny? should i try to make the hole on the ring gear bigger? any ideas? </TD></TR></TABLE>
i would tell you to try a gsr ring gear, or a itr ring gear. the gsr ring gear, will be easier for you to find! btw the itr & gsr ring gears, share the same size/bolt pattern! good luck!
Modified by smokey2.0 at 10:10 AM 4/16/2005
Old Apr 16, 2005 | 02:11 AM
Roky's Avatar
thanks. do you have an idea where i could get a gsr ring gear?
Old Apr 16, 2005 | 03:38 AM
SlowReaction's Avatar
CTR and ITR diff are the same. You can use gsr or itr ring gear. best bet is to post a wtb add in the classifieds or buy a new one from honda.
Old Apr 16, 2005 | 07:09 AM
smokey2.0's Avatar
Default Re: type-r LSD into B16A2 -> problem (SlowReaction)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlowReaction &raquo;</TD></TR><TR><TD CLASS="quote">CTR and ITR diff are the same. You can use gsr or itr ring gear. best bet is to post a wtb add in the classifieds or buy a new one from honda.</TD></TR></TABLE>
thankx for clarifying that, but i would tell you to search for gsr ring gear. from the dealer, it will cost you $$$$
Old Apr 16, 2005 | 03:04 PM
Kendall's Avatar
This is a prime opportunity to go ahead and upgrade to a 4.7 or a 4.9 final drive. I believe Hmotorsonline has the 4.7 for $375 shipped.
playlife
Jun 3, 2011 12:12 PM
zimmy709
Jun 25, 2008 04:06 PM
PrecisionH23a
Apr 29, 2006 09:29 AM
