Brake/clutch trouble
Old Apr 15, 2005 | 10:06 AM
eric416's Avatar
Default Brake/clutch trouble
My abs light just went on 2 days ago and today when i drove the car, the clutch pedal fell pretty much to the floor with no resistance like it usually has. It engages at the last inch or 2 now. The brakes feel fine. Could these 2 things be related? what should i check
Old Apr 15, 2005 | 11:20 AM
RemerLex11's Avatar
Default Re: Brake/clutch trouble (eric416)
start by checking brake and clutch fluid
Old Apr 15, 2005 | 12:07 PM
IHateJDM's Avatar
Default Re: Brake/clutch trouble (Matt5745767)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Matt5745767 &raquo;</TD></TR><TR><TD CLASS="quote">start by checking brake and clutch fluid </TD></TR></TABLE>
If clutch fluid is low, look for fluid behind the pedal under the carpet. If so, you need a new clutch master cylinder. The abs is a seperate problem
Old Apr 17, 2005 | 09:09 PM
eric416's Avatar
Default Re: Brake/clutch trouble (IHateJDM)
Where can i check the clutch fluid?
Old Apr 18, 2005 | 06:21 AM
RemerLex11's Avatar
its the small bottle right next to the brake fluid and it should be about half way full. if you look at it closely it says clutch fluid on it.
Old Apr 24, 2005 | 04:59 PM
eric416's Avatar
so i fixed the problem today, it was the clutch master cylinder. I guess it was some how related to the brake problem because the abs light went away. I dont see how though
ray.riddler92
May 4, 2011 01:00 PM
powerdbygarrett
Oct 17, 2007 07:42 AM
Prelude4ws
Nov 28, 2006 06:19 AM
magic hat #9
Aug 23, 2002 09:21 AM
Malice
Feb 4, 2002 08:16 AM
