Installed new Dizzy- But NOW, Check Engine Light is ON.....
Old Apr 15, 2005 | 09:06 AM
OneBadDC2's Avatar
Default Installed new Dizzy- But NOW, Check Engine Light is ON.....
Okay, well i was driving monday and my car died. Wouldnt start, so i narrowed it down the dizzy, installed a new ignitier, Nope..Then i just decided to get an entire new Dizzy. Just incase the old one had an internal problem beyond repair. I just installed the new one and YAY, my car cranked up. But now the check engine light is on, and before, this was never on. What could be my problem? Any suggestions.
Info:
B20B
LS Tranny
94 LS OBD-1 Distributor
Old Apr 15, 2005 | 09:13 AM
Luserkid's Avatar
Default Re: Installed new Dizzy- But NOW, Check Engine Light is ON..... (OneBadDC2)
Whats the code?
Old Apr 15, 2005 | 09:49 AM
OneBadDC2's Avatar
Default Re: Installed new Dizzy- But NOW, Check Engine Light is ON..... (Luserkid)
It wont produce a code, the CEL comes on when the car runs, but when i jump the ecu, the CEL won't come on. I don't know what to do...
Old Apr 15, 2005 | 10:25 AM
Econo'Box's Avatar
Try resseting it.
Old Apr 15, 2005 | 10:40 AM
PureBlood's Avatar
Reset it, you can't get a code since there's no problem, the ecu is remembering the problem with your old dizzy, if that was still in the car, you'd get a code.
Old Apr 15, 2005 | 03:07 PM
OneBadDC2's Avatar
Default Re: (PureBlood)
i did reset it..still on when i drive. Also the CEL never came on when i broke down too. But now with a new dist. its on constantly when i drive.
dont know what to do.
Old Apr 15, 2005 | 03:25 PM
Marauder's Avatar
Default Re: (OneBadDC2)
Go to a auto parts store and have them pull the code. There is no way the CEL can be on and the ECU not tell you which code it is.
Its just hard to help fix a problem, when you need to know why the ECU is freaking out....and the code is the key to fixing it.
Old Apr 16, 2005 | 02:26 PM
OneBadDC2's Avatar
I got a read..
CODE 8
TDC Position,
now what do i do?
Has anyone had this problem when putting on a Brand New Distributor?
Old Apr 17, 2005 | 03:11 PM
PureBlood's Avatar
that messed.... the dizzy can only install one way and still spin.... is to too far advanced or retarded maybe? I couldn't see how you're getting that code unless the new Distributor is screwed up..... Sorry i can't find much info..
TDC Sensor (Top Dead Center)
defective circuit or unplugged / defective sensor
its gotta be a bad unit, or just bad timing and a sensor somehwere else killed itself.... im assuming the dizzy you got has a warranty? take it back and grab another
Old Apr 17, 2005 | 03:19 PM
jlacoy82's Avatar
71.192.16.183
Someone I talk with had this problem recently, the pin on the ECU for that sensor had fallen out of his obd conversion harness, plugged it back in and no more code.
Tasp72
Feb 14, 2016 04:28 AM
blaze.1
Sep 24, 2009 11:04 AM
Sam268
Sep 13, 2004 01:11 PM
hondalude9394
Nov 9, 2002 12:17 PM
wadafa
11
Oct 3, 2002 03:49 PM
