fuses
ever since i've had my car, my internal light doesnt work, and a few things like cruise control and etc, i see the man that sold me the car tried to do some fuses work since the cover was in the trunk. how could i fix my fuses? and how much would it cost to take it to a shop to have them fix it?
thanks
thanks
you have to find out what fuses are used to controll the parts you are talking about
then find that fuse in the cabin right under the steering wheel or in the engine bay by the pass side shock tower
pull the fuse and check if the little metal strip inside the fuse is broke if it is just replace it with the same fuse (i.e) if its a 10amp fuse replace with a 10 amp
if its a 20amp replace with a 20amp and so on
Mishima
Jun 30, 2009 09:08 PM
FRKWOO
13
May 28, 2009 11:48 AM
